No there shouldn't be any problems with getting a little on the rotor face. The first time or so you press your brake pedal it will come off by the friction of the pads and the rotor. I have always wonder if/how that plays a role in the life of the pad of at all...
I've watched a couple people take no consideration with how much paint ends up on the rotor......... They have had no ill effects, and the paint is gone from the contact area after the first time around the block.
I took mine apart which proved to be easy compared to some assemblies that I've tackled..... You may need a set of 6 point sockets to get them loose.
