I was just getting on here to say I found a local shop that was going to punch out the pattern for me, but now that I see this, I'll get on it.
Must be a newer dodge. The pattern on the '01 era is too large of an opening.
I also seen the Dodge grills and thought it came pretty close, all the mesh I've seen don't do a thing for me except for maybe modder's mesh that is hexagon shaped but very small. Didn't know there was a difference between the Dodge grills, may start looking again.
Thanks for the link, think they look pretty nice in there, would also like to know how he attached them.
Can anyone get a measurement on the hole opening across the flats on the hexagon shape in a newer ('03+) dodge grille? I just measured an '01 and it is just under 3/4". The openings on our stock nose grilles are 1/2".
I wanna try this now.. looks sweet. You could alway cut some of the top of the grille so it sits farther forward and actually pops out of the lower fascia.
It's not so much, for me, the opening sizes matching perfectly. The ones in my hood are smaller, yet. For me, it's the size of stone or road debris that can pass through the larger opening. The smaller the hole, the smaller the stone that can pelt my condensor.
I just looked at photos of an '01 and a '96 and both have about 41 or 42 columns of openings per grille.
29 columns in an '02-'05 grille
I'm not sure of the physical dimensions of either grille, though.
Yeah, I think I might do the same thing. As close as it is, it will probably work just fine for my needs and I think one grille would do two GP cars, by the looks of it.
I like what newarkk is saying, too. What could be used for a "border" around the outer perimeter to make it look finished?
Any idea on what the material is on the grilles? I have an uncle that may be able to do a "plastic" type of weld of material to the outside of the parent material.
Anyone do this yet since we've started gabbing about it? I found some edge trim in McMaster Carr that would probably work well to create a finished edge. It's kind of pricey, but we'd only do it one time.
