Thread: Rust on Fender. Estimate?
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21 Re: Rust on Fender. Estimate?
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by ramairgt2 View Post
    another terrible rust area on our car is the rocker panels. They rust out terribly. I think I have pics floating around some where of that rust. I've also got the same flaking issues too.
    I'm still in the process of doing more body work to my car but I'm looking at houses at the same time plus working full time and the family.
    This is true. But the deal here is, most of us drive GT's and GTP's and will never see that area unless our body kits are removed. Those driving SE's, particularly here in the midwest and further up north will see lots of it since the rust usually comes from the salt on the roads in the winter.
  2. #22 Re: Rust on Fender. Estimate?
    GT Level Member hourang's Avatar
    commerce, mi
    Quote Originally Posted by beckys2000gt View Post
    no, just for the stuff on my fenders, you dont even wanna know about the under the gastank!!! and the trunk? im not worried about it, im getting a new one.
    and like i said before she was a DAMN good deal, a little bit of body work doesnt scare me
    curious how much they quoted you for under the gas tank. i need mine done eventually. also incude what they are doing for that price, obviously you need new metal but are they welding new metal on or glueing it on? and does it include priming, sanding, filler and paint?
    -Jeff
    98 GTP Black 4dr - fully loaded - short ram intake, tinted tails, hole in resonator.
    sold 98 camaro ss - 6spd fully loaded - cam, intake, exhaust, ford 9in rear 4.11s, 6point chromoly cage, tnt 150shot nitrous, nittos, etc.
  3. #23 Re: Rust on Fender. Estimate?
    Nov 2008
    Waterloo, Iowa
    Quote Originally Posted by hourang View Post
    Unless a panel is rusted through, you do not need new metal.
    And holy ****, glue? Damn if they glued a piece of metal to my car versus welding it, I'd **** bricks and merk them all... with lasers.
    Under her gas tank looks fine, some sanding, then depending how deep it is, filler, then sand prime and paint, it'll be fine.
  4. #24 Re: Rust on Fender. Estimate?
    Arizona
    ahhh so nice to live in az... where rust isnt a problem
    '00 GT- nothing special
  5. #25 Re: Rust on Fender. Estimate?
    commerce, mi
    Quote Originally Posted by SaW1833 View Post
    HowStuffWorks "Is it possible to assemble a car with glue?"
    No-Weld auto body repair panel job
    i think mine is rusted through, but i guess i wont know until sanding.
    -Jeff
  6. #26 Re: Rust on Fender. Estimate?
    I was under the impression that our cars chassis were assembled in two pieces then glued together right around the C pillar.
  7. #27 Re: Rust on Fender. Estimate?
    Nov 2008
    Waterloo, Iowa
    I guess I learned something today. I just never thought glue on heavy pieces sounded feasible moving at high speeds...
  8. #28 Re: Rust on Fender. Estimate?
    commerce, mi
    jb weld is a glue/epoxy.
    -Jeff
  9. #29 Re: Rust on Fender. Estimate?
    commerce, mi
    im pretty sure they epoxy'd a panel on trucks tv.
    -Jeff
  10. #30 Re: Rust on Fender. Estimate?
    Nov 2008
    Waterloo, Iowa
    Aha okay. It's the word... glue. Glue sounds weak, epoxy doesn't. I think glue, I don't think stuff like this. Epoxy is a better word...
  11. #31 Re: Rust on Fender. Estimate?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    This is coming through from the back side. "Fixing" this the way you mentioned will result in a temporary fix only, cosmetically. Without cutting all the rusted metal out and welding new in, it will come back in a short time period.
  1. Hey i got an Estimate today and need to advice.
    By AmericanRiceEater in forum Visual/Body Modifications
    Last Post: 03-31-2010, 05:02 PM
  2. Ive got rust
    By MikeZirpola in forum Visual/Body Modifications
    Last Post: 09-24-2009, 01:08 PM
  3. so 60k miles a good estimate??
    By 16MustangVet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-29-2009, 04:00 PM
  4. How to Tune the MPG estimate in the DIC.
    By lightfoot__ in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-18-2008, 11:51 AM
  5. Can You Estimate My 1/4 now?
    By BLACKEDOUTGTP in forum Off Topic Discussion
    Last Post: 01-05-2008, 12:28 PM
