I would like to remove my stock fog lights and clean them, how easy is it to get them out? Im not in the market for new ones right now so I want to get these cleaned up. Also, whats suggessted for cleaning them?
Pretty easy..
# Jack up the front end of the car up to give yourself more room.
# Disconnect your negative battery terminal using a 8mm socket and rachet.
# Using a 10mm socket, remove the two nuts from the back of each of the fog lights.
# Remove each foglight, and unclip the wiring harness.
^^X3. If they are hazed over like the headlights tend to get then try the 3M headlight restoration kit. I was impressed with the results. If they are not then some elbow grease with a product like meguiars plastix seems to do a decent job.
