Thread: Fixing leaking corner lights, through lamps.
Results 1 to 6 of 6
  1. #1 Fixing leaking corner lights, through lamps.
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    I bought some eBay special headlights, and thought one of them was leaking into the corner lights. Well, after buying another pair of corners from someone on hear, the same corner is leaking. This leads me to believe it's not the corner piece but its coming in through the amber corner light. How can I seal this? Can the rubber gasket be replaced? Someone suggested vasoline between the gasket and plastic. What is the easiest way to dry out the lamp before sealing it up?
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Fixing leaking corner lights, through lamps.
    a hair dryer. i actually just fixed my black headlights this past weekend! i used black silicone along the outside of where the lense meets the headlight. worked 4 me!
  3. #3 Re: Fixing leaking corner lights, through lamps.
    SE Level Member Houdini's Avatar
    Water goes down the shelf between the hood and fender and lands right on top of the bulb opening. Go to a salvage yard and get a gasket that goes around the bulb socket. One from any GM car should work
  4. #4 Re: Fixing leaking corner lights, through lamps.
    Feb 2008
    Cumming GA
    Quote Originally Posted by Houdini View Post
    That's what I thought. When I opened up the hood and removed the offending bulb, I watched a drip from the bad gasket leak right in. I've got a few things to order from Ed Morad, so maybe he's got one or two he can throw in.
  5. #5 Re: Fixing leaking corner lights, through lamps.
    GTX Level Member LowlyfeGTP's Avatar
    Janesville, WI
    Yep, those are the two most common problem places. Silicone around the headlight and good gaskets.
    Jason Klingaman
    LOWLYFE
    99 GTP Silvermist Coupe
    360 vid
  6. #6 Re: Fixing leaking corner lights, through lamps.
    Feb 2008
    Cumming GA
    Since the same corner light started leaking after replacing both, I'm guessing it's the gasket and not the light.
  1. Clear Corner Lenses
    By TCO in forum General Tech Discussion
    Last Post: 04-30-2008, 11:25 PM
  2. looking for new fog lamps
    By ayman in forum Visual/Body Modifications
    Last Post: 04-03-2008, 11:30 AM
  3. how long and what temp in the oven to separate corner lense?
    By Zainoman in forum Off Topic Discussion
    Last Post: 03-15-2008, 02:40 AM
  4. Fixing a deep scratch/chip
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 03-01-2008, 09:04 AM
  5. L.E.D Tail lamps
    By Dohner in forum Visual/Body Modifications
    Last Post: 02-09-2008, 05:34 PM
