Thread: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
Results 1 to 18 of 18
  1. #1 Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    GTX Level Member LowlyfeGTP's Avatar
    Janesville, WI
    Two weeks left on group buy pricing (ends this month). I have received my black projectors and they are very high quality. I have not installed them yet as I want to mod mine, but I have to get the balls to try to remove the outer lens first. Anyways, contact info first.
    John Lee
    SpyderAuto.com
    881 South Azusa Ave
    City of Industry, CA 91748
    (626)934-8884 ext 185
    Projectors are available for ordering NOW
    Black and Chrome are in stock.
    9005 and H1 halogen bulbs are included
    Black & Chrome Group Buy Pricing: $350 ($450 with 8000k H1 HIDs) shipped in the USA / $370 Canada. / Elsewhere, contact me first.
    Payments accepted: PayPal (preferred!!) and Credit Card.
    PayPal address: John@Spyderauto.com
    -Please provide shipping address and Color Projector.
    Credit Card:
    Fax info to (626)934.8885 / Call Mon-Fri 930am-530pm pst 626-934-8884 xt 185
    -Need following information:
    Full name
    Billing & Shipping Adresses
    Credit Card Number, Expiration Date, & Cvc Code
    Phone Number
    Color Projector You want.
    Jason Klingaman
    LOWLYFE
    99 GTP Silvermist Coupe
    360 vid
  2. #2 Parking Light Alarm Flash
    Janesville, WI
    I am by no means an expert when it comes to Projectors, wiring, etc. I will answer the best I can with others info I have picked up here and CGP. I personally plan to run H1 HIDs and 9005 Halogens, halos will be wired into the PL, low beams will stay on with high beams, alarm flash will be parking lights no headlights.
    Here goes, I will try to credit the members originally posting this info.
    Parking Light Flash
    Parking lights alarm flash, for those with HIDs: (BackInBlack)
    Modification to re-route the acknowledgement headlamp flashes from the theft deterrant relay to the parking lights...
    This should do it: (Disconnect battery before performing surgery on the car!)
    1) Find the theft deterrant relay in the driver's side kick panel. It will have 1 or 2 orange wires, a white wire, and a YELLOW wire in the harness.
    2) Cut the yellow wire, and splice it into the BROWN wire at the headlamp switch. (See diagram below)
    3) Tape up the YELLOW wire that runs back into the body harness. When the headlights are on, this wire will become live, and we don't want it shorting out and causing a fire. Also be sure your splice is insulated as well.
    The YELLOW wire is located on the connector in the driver's kick panel for the theft deterrant relay. (I can't show you pics, because I do not have this relay in my car.)
    The BROWN wire is at the headlamp switch connector, pin R.
    Do not cut any yellow wires in the headlamp switch harness.
    That should do it! Since the parking lights are isolated by the relay contacts, no isolation diodes are necessary.
    Updated 1997-1999
    2001-2003
    Cut the WHITE wire at pin D11 on the BCM. Insulate the car side. Tie the BCM side of the wire to one side of a standard 30A 12v automotive relay coil. Tie the other side of the coil to the NO contact of the relay AND the ORANGE wire at pin O on the headlamp switch. Tie the common (COM) of the relay contact to the BROWN wire at pin R on the headlamp switch. Bridge across the relay coil with a 1N4004 diode to protect the BCM output. The stripe side of the diode is oriented towards the ORANGE headlamp wire.
    Updated 2001-2003
    This modification modifies your cars wiring to reroute the stock keyless entry headlamp flash to the parking lamps instead. This will help save your HID ballasts as well. Parts required: 30A 12vdc automotive cube relay 1N4004 Diode Wire Disconnect negative battery terminal. Locate the white wire at location C11 in the BCM harness. Cut it and insulate the vehicle side. Tie this wire to pin 86 of a generic 12v automotive cube relay. Bridge pins 85 and 86 with a suppression diode to protect the BCM. Tie pin 30 to the brown wire R in the headlamp switch harness. Tie pins 85 and 87 together and tap them into the orange wire O in the headlamp switch harness.
    Jason Klingaman
    LOWLYFE
    360 vid
  3. #3 Highs(9005)/Lows(H1 HIDs) On Simultaneously
    Janesville, WI
    Highs/Lows On At The Same Time
    Highs(9005)/Lows(HIDs) On Simultaneously (Chunkee)
    No pictures for now, just some wiring insight
    For those who choose to do HID lows and HID highs, very simple
    Run one set of ballasts for low beams with a wiring (relay) harness connected to the OEM headlight connector so DRL's will work (this allows the correct voltage to get to the headlights without killing the ballasts with low voltage). Use one side (passenger or driver) for this. I am using Bi-Xenon wiring harness for lows (more on that in a sec)
    Run second set of ballasts for high beams off the OEM headlight connector (on the other side not used for low beams) by swapping the wires in the wiring harness (on mine it goes red, black, blue. Swap the red and blue around so low is high and high is low)
    By using the bi-xenon wiring harness you can have both lows and highs on at the same time
    Also, using the bi-xenon wiring harness allows for both low and high HID lights to be on at the same time because that is the way the Bi-Xenons work...all it does is trigger the magnet part to move, unhook that connector for the magnet and low or high position results in lows always being on. Wire in another harness for just the highs and low = low and high = low and highs at same time, just remember to swap the low and high beam wires in the high beam OEM adapter or low = low and highs and high = low
    Harness: Ebay:
    hid wiring harness, Parts Accessories, Car Electronics items on eBay.com
    I guess you could always just use both the low and the high beam wires off the OEM adapter (green and oarnge-brown) for the lows that way the turn-on signal the wiring harness gets will shift from low to high when highs are turned on. I just do not know if the bulbs will turn off then on again in that scenario (like if you were to hold the high beams on, there is a pause sometimes when switching between low and high) then use just the high beam wire for the high beam HIDs.
    (Mike Levy) If you don't run the harness to feed the lights from the battery, you are going to have times when one doesn't ignite or stay lit. The factory wiring isn't thick enough to provide the power needed to light and keep them both on, unless conditions are perfect.
    (Chunkee) Plus when your DRL's are on, that is a lower voltage and will destroy a ballast before you know it.
    Always use harnesses
    High(9005)/Low(HIDs) on Simultaneously (99 Black GT)
    this is a VERY basic drawing. You would need a relay for each headlight (technically you could get away with only using one, but i wouldn't) It's best to pick up a relay socket, and put an electrically conductive grease on it so it doesn't corrode. And then i run NEW wires, from the fuse block, to make sure i get full voltage to the HID's (much like the SUV harnesses)
    on the relay it'self, the connections would be as follows
    85:: Ground
    86:: Diode isolated Low + High wires together
    30:: To the HID ballast
    87:: From the fused +12 you get from your fuse box
    relays are cheap, the diodes wouldn't have to be any more than a 1 amp rectifier diode (cheap) and enough wire for new grounds and getting power from the fuse box. The new harness could probably be done for under $15 for the pair of headlights. Or less if you're a good shopper.
    Another Possibility
    High/Low, flash to pass. (BackInBlack)
    The diagram below is for use with underhood relay harness only, or the HID low/ halogen high 9007-2 setup. Forest fires may result from using this mod with halogen bulbs installed on stock wiring.
    9007-1: Single HID burner.
    9007-2: Single HID burner w/ halogen high.
    9007-3: Single HID burner w/ tilt or retracting action for high mode.
    9007-4: DUAL HID burner (Bi-Xenon) one for low, one for high.
    There is a solution that will turn the lows and highs on at the same time, but also make it so the 'flash to pass' will only turn on the highs. Just follow this wiring diagram by BackInBlack.
    How are the new projector housings wired? Are there SEPARATE ground wires for the highs and lows? If there is only one ground, you should NOT have the high beams and low beams on at the same time unless the ground wire is 10AWG or better and the connections are rated for such.
    **Again, I can not vouch for the above info. Provided info is for use with H1 HIDs in projectors.**
    Jason Klingaman
    LOWLYFE
    360 vid
  4. #4 Aiming
    Janesville, WI
    Alignment of Projectors
    8mm Bolt, height adjustment
    Left/Right adjustment (Preotic)
    To align the projectors correctly first you need to:
    1) Measure from the ground to little dot on the lens in front of projector.
    2) Subtract 2.5 inches off that measurement, then make a mark on the wall. That you're going to be aligning your headlights with.
    3) Put your car 25 feet away from the wall trying to get as perpendicular to wall as possible and on level ground.
    4) Adjust the headlight so that the _______/ of the cut-off is level with your mark on the wall. And thats it for the height
    For the width you measure from the middle of one projector to the other side. Take that measurement and get the step up on the cut-off 3-4 foot away from the other.
    I could only get mine 2.5 feet away from each other before the gap between the center of the car and the corner of the headlight became too big.
    USE DIAGRAM C
    Revised showing measuring points
    Another Diagram
    Another Aiming Source
    http://www.coolbulbs.com/HID-VISUAL-...-PROCEDURE.pdf
    A more indepth website for adjusting your headlights.
    Automotive lighting FAQ - Headlamp aiming
    **The design of our headlights were not meant for projectors so some of the measurements and alignment may be slightly off and is just a guidline. Adjust to your content.**
    Jason Klingaman
    LOWLYFE
    360 vid
  5. #5 General Info
    Janesville, WI
    General Info:
    1) Before installing let temperature equalize. Install in as dry and warm of a location as possible to avoid moisture in the projectors.
    2) Make sure you have both tabs on the back of the headlights inserted properly in the slots.
    3) Make sure metal supports on your car are evenly space. At least one member found his were uneven.
    4) These are intended to be used with halogen bulbs, not HIDs. Use of them immediately voids manufacturers warranty.
    5) It is possible not all H1 HID kits will fit without minor modification.
    6) If you have an existing kit you can just buy an H1 HID bulb to replace the 9007 HID bulb. W-body Store, etc. specifically is selling just bulbs for this reason now.
    7) If you don't like the Egg Yolk stock turn/PL bulbs you can replace them with the stealth bulbs or my preferrence of LED switchbacks.
    LED switchbacks for turn signal
    3157 Tail Light Brake Light Turn Signal LED Bulbs
    8) Stock low beam H1 and high beam 9005 halogen bulbs are included.
    9) Make sure all mounts, brackets, etc. are tight before install. It is possible to get bounce out of these if not. May anyways, as with stock. Try re-installing, adjusting, assisst if necessary.
    10) GTS and Auto Ventshade headlight covers do not fit on these lights due to the "bubble". I will be trying to remedy this on my own set.
    11) I am in no way associated with SpyderAuto, other than as a customer and helping John when I can.
    12) I will add any additional thoughts/info as it becomes available.
    Jason Klingaman
    LOWLYFE
    360 vid
  6. #6 Random Pics
    Janesville, WI
    If any member who's GP is pictured would like it removed let me know.
    Jason Klingaman
    LOWLYFE
    360 vid
  7. #7 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    GT Level Member drunknmunky's Avatar
    McDonough/Warner Robins, GA
    amazing post. very informative! thanks jason... this helps alot! rep!
  8. #8 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    GT Level Member BackInBlack's Avatar
    Vermont
    I did some updated drawings in the "upgrades" tab at clubgp. You might want to use those diagrams instead of my showing off my ms-paint skills, or lack thereof...
    The GPs are long gone...
  9. #9 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    Janesville, WI
    Thanks! Glad I could help.
    I was hoping you would jump in. You have been my main source of info throughout the years when it comes to things like this.
    I added the updated info above instead of deleting it as some may find one diagram easier over another. Thanks for letting me know.
    Jason Klingaman
    LOWLYFE
    360 vid
  10. #10 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    GT Level Member GOINDEF's Avatar
    Holly, MI
    hey everyone, I finally got my headlights all done. I've got the upgraded wiring for the headlights and the foglights. I have projector foglights with halo's as well. All my lights are HID's, high-4300k lows-6000k fogs-4300k, and boy do they look killer at night. here's some pictures of it all. I was a lil painfull to take the dremel to the housing for the bulbs, but it was well worth it.
    all halo's on
    stock and new headlights w/ HID
    HID Foglights
    HID Low's and highs
  11. #11 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    May 2008
    Does anyone have a thorough write up on how to do the halo's for the projectors? Just want to get this right the first time and not screw anything up. Thanks!!!
  12. #12 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    Janesville, WI
    Quote Originally Posted by rocket69GTP View Post
    Halos are a personalized choice. All it is is a positive and negative. At least half a dozen ways to hook them up. Depends on how you want them to work. With PL, fogs, DRLs, blinkers, etc. I'd use connectors that can be unhooked so you can easily remove the headlights.
    Jason Klingaman
    LOWLYFE
    360 vid
  13. #13 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    May 2008
    I was thinking of using the same thing as far as snap on connectors but did not know how many black wires were used as a ground and if I am using the brown wire as a power source if I would just wire them up to the positive side of the halo's etc..... Not exactly electrician savy. Thanks again.
  14. #14 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    So whats the light output like compared to stock? just curious.
  15. #15 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    May 2012
    Canada
    i just got the exact same lights and the light housings bounch like no tomorrow, i have temporarely fixed that but the projectors are pointed in oposite directions thay are just a huge pain at the moment. Just want to know if anyone else has had problems such as this, and if so how did you fix it.
  16. #16 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    GTX Level Member blackflag's Avatar
    Virginia
    necropost... anyway, weather stripping underneath housing works
  17. #17 Re: Highs(9005)/Lows(H1 HIDs) On Simultaneously
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Quote Originally Posted by LowlyfeGTP View Post
    This worked like a charm, now does anyone know how to wire your fog lights so they DO NOT turn off when High Beams are on?
  18. #18 Re: Projector General Info (Aiming, PL flash, High/Low, Pics, etc.)
    SE Level Member Osvaldo831's Avatar
    Jun 2012
    Salinas
    Awsome thread, So those halo headlight projectors have a h1 bulb and 9005 in the same assembly? i been looking for something like this
  1. Official SpyderAuto Projector Headlights Info
    By john@SpyderAuto in forum Visual/Body Modifications
    Last Post: 02-07-2010, 08:36 PM
  2. projector headlights for 2006
    By gp689 in forum Visual/Body Modifications
    Last Post: 03-01-2009, 11:21 AM
  3. projector headlights
    By 3800SE in forum Visual/Body Modifications
    Last Post: 10-15-2008, 07:57 AM
  4. More 2009 ZR1 info and DETAILED LS9 pics!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 01-11-2008, 05:47 AM
  5. How about a General W-body section
    By Andrew_99GTP in forum Forum Bugs/Suggestions
    Last Post: 01-01-2008, 02:17 PM
