Thread: Painting help
Results 1 to 9 of 9
  1. #1 Painting help
    London Ont, Canada
    ive been doing some painting on the car as some of you know lol
    today after i sprayed i noticed some fisheyes in one corner.. its happened before too.. so i wonder, to all the pro body guys out there/someone who has painted thier car before..
    what are you using to clean the surface after sanding to make sure its clean?? I think im missing something.
  2. #2 Re: Painting help
    Donating Users JESSEGOTTA GP GT's Avatar
    NC
    I've always sanded with 400 grit after I put 2 coats of primer on, then wiped it all down with mineral spirits and everything stuck fine.
    New project: 2000 Red GTP.
  3. #3 Re: Painting help
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    what kinda paint are you using air can or spray gun?? and u have to use a good (wax and grease remover) or not shyt is gona stick
  4. #4 Re: Painting help
    London Ont, Canada
    Using a gun, and i used wax/grease remover, but still happening.. is there something i can use to ensure the wax/grease remover is all gone? maybe its some residue thats causing the issues.
  5. #5 Re: Painting help
    London Ont, Canada
    Bump...
  6. #6 Re: Painting help
    NC
    Try spraying it in even thin coats, or just a real thin first coat.
  7. #7 Re: Painting help
    Feb 2010
    ohio
    ^^agree thin coats let stand for awhile then keep repeating
  8. #8 Re: Painting help
    Feb 2010
    ohio
    and i use dupont wax a grease remover the best what part of the car are you havin problems with?? ground effects, fenders,bumpers???
  9. #9 Re: Painting help
    London Ont, Canada
    Its no particular section , its just spots of fisheyes.. i use wax and grease remover, then wipe the surface down making sure to get every spot, then using new towel wipe it again, then again until the towel comes back clean then i let it sit for a few minutes to make sure that its all evaporated, then spray..
  1. Painting on Roof?
    By GAFF in forum Visual/Body Modifications
    Last Post: 04-12-2010, 08:12 PM
  2. Re-Painting my KYB AGX
    By Quicklynx in forum Visual/Body Modifications
    Last Post: 05-13-2009, 01:56 AM
  3. hood painting?
    By kassel98gt in forum Visual/Body Modifications
    Last Post: 05-10-2009, 06:18 PM
  4. Painting Pricing
    By TCO in forum Visual/Body Modifications
    Last Post: 02-08-2009, 12:30 PM
  5. painting
    By datApocalypse in forum Visual/Body Modifications
    Last Post: 02-12-2008, 04:53 AM
