Thread: *** Ultimate HID thread ***
Page 12 of 18 FirstFirst ... 21011121314 ... LastLast
Results 221 to 240 of 358
  1. #221 Re: *** Ultimate HID thread ***
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    you modify the housing so it sits at the right distance.
    makes better sense...thank you...I may just leave that alone then.
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  2. #222 Re: *** Ultimate HID thread ***
    the bulb housing.
    not your headlight housings....
  3. #223 Re: *** Ultimate HID thread ***
    Aug 2008
    Fayetteville, NC
    the bulb housing.
    Yeah I know what you mean but I just don't have that skill...so best to leave them be before I mess 'em up.
  4. #224 Re: *** Ultimate HID thread ***
    true
  5. #225 Re: *** Ultimate HID thread ***
    Aug 2008
    Fayetteville, NC
  6. #226 Re: *** Ultimate HID thread ***
    Aug 2008
    KCMO
    looks good what K? whos G8?
  7. #227 Re: *** Ultimate HID thread ***
    Aug 2008
    Fayetteville, NC
    6000K and my dads G8 GT. hah, I wish it was mine. he's about to get 2 black stripes painted down it.
  8. #228 Re: *** Ultimate HID thread ***
    GTX Level Member 03GTPLE's Avatar
    Tyler, TX
    Quote Originally Posted by offroadfury6 View Post
    my issue with my HID is that they are not bright enough, I bought them from DDMtuning, they are the same brightness as my slyvania ultras...
    ...just in case a 97-03 owner reads the previous statement and just wants to go down and get Silverstar Ultra bulbs, don't - here's why:
    For the stock 2003 housings, the Silverstar Ultras do not even come close to the same output compared to my DDM HIDs. The DDM tuning HIDs are almost too bright, and they light up everything. Everyonce in a while I'll get flashed from people that think my brights are on. ....my buddy says they are too bright... I absolutely love them and will recommend them to anyone.
    2003 White Grand Prix GTP Limited Edition
    - 3.4 pulley, tune by Boostd1/CLINT@AIR, Short Ram Intake, PLOG, 3" ZZP Downpipe, AL 104's, 180* t-stat, Impala STB & 12" cross drilled/slotted/zinc washed rotors, DDM HID's, and put in a heads up display for now...
  9. #229 Re: *** Ultimate HID thread ***
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by 03GTPLE View Post
    I wish I had the same experience with my 06. I think moddifying the bulb is needed in my case
  10. #230 Re: *** Ultimate HID thread ***
    Brightening up your day. Koniig's Avatar
    Jun 2010
    Illinois.
    To fit the 9006 bulb in for your low beam?
  11. #231 Re: *** Ultimate HID thread ***
    Aug 2008
    Fayetteville, NC
    Quote Originally Posted by Koniig View Post
    no, they fit...I mean modify the bulb...See the very first page of this thread...
  12. #232 Re: *** Ultimate HID thread ***
    Jun 2010
    Illinois.
    Oh gotcha.
  13. #233 Re: *** Ultimate HID thread ***
    Tyler, TX
    With my DDM kit, there is no need to buy the error eliminator. The DDM kit leaves the passenger side OEM bulb unplugged because ther DDM harness only connects to one bulb connection. For some reason, the brights indicator on my dash and HUD is constantly on. It's dimmer when the brights are not actually on, but it's still there.
    I plugged in a stock bulb to see what would happen and it fixed the brights indicator on the HUD and dash. Since I have the 9004 bulb plugged into the stock harness, I now have an underhood light.
  14. #234 Re: *** Ultimate HID thread ***
    Jun 2010
    Illinois.
    A headlight bulb??
  15. #235 Re: *** Ultimate HID thread ***
    Tyler, TX
    yeah, just put a stock bulb in the factory harness connector that is seperate from the HID wiring. Here's what I'm talking about, you can see the HID plugged into the headlight housing, connected to the DDM HID wiring harness, then below that is the factory headlight harness and a 9004 regular bulb plugged into that. This is only on the driver's side because on the passenger side the factory harness plugs into the DDM HID harness. Again, I only plugged in the regular 9004 bulb into the harness to prevent the brights indicator to turn off on the dash and HUD. The HIDs worked perfectly without doing this.
  16. #236 Re: *** Ultimate HID thread ***
    ghettooooooooo
    I didn't need to do this at all and i'm running a harness that only connects to the passenger side for that, but connects to the drivers side for the high beam(9007-3 bulb, hate the bulb, no high beams)
  17. #237 Re: *** Ultimate HID thread ***
    Tyler, TX
    eh... ok.... I can also break off the bulb and tuck it under the housing in the bumper... i just don't care right now.
  18. #238 Re: *** Ultimate HID thread ***
    Jun 2010
    Illinois.
    So when you open your hood and your headlights are on, it's like the ****ing sun under your hood? Jesus, I just can't imagine how bright and how hot that would be? Correct me if I'm wrong..
  19. #239 Re: *** Ultimate HID thread ***
    Tyler, TX
    no no, you are right, I do have an underhood light now. It's not that bright since there aren't any reflectors. Doesn't even light up the entire engine bay at night.
  20. #240 Re: *** Ultimate HID thread ***
    Toronto
    I wanna put HID's in my driving/signal lights, is it bad for an HID light to flash as it's working as a signal all the time?
  1. Ultimate PEEP show!!!
    By Trannyman95 in forum Off Topic Discussion
    Last Post: 03-09-2008, 06:40 PM
  2. My car pic thread
    By thelongone13 in forum Off Topic Discussion
    Last Post: 02-11-2008, 11:23 AM
  3. can find a certain thread...
    By gp4u2c in forum Off Topic Discussion
    Last Post: 01-20-2008, 01:54 AM
