Thread: Gen V I polished
Results 1 to 10 of 10
  1. #1 Gen V I polished
    Jan 2009
    Grand Rapids, MI
    This is the second blower I've polished and it turned out great.
    XP~GEN V~SSIC~2.8~HEADERS~P&P HEADS~78mm TB~SLP LOUDMOUTH
    318 whp, pump 92 octane, 18" wheels
    Before Gen V
  2. #2 Re: Gen V I polished
    SE Level Member 2k6GT's Avatar
    Troy
    Hey can you pm me how long that took and what special method you use??.. That look amazing man
    At 200 MPH you have no friends......Just Balls.....
  3. #3 Re: Gen V I polished
    London Ont, Canada
    Looks good - how did ya do it? what did ya use?
  4. #4 Re: Gen V I polished
    Apr 2009
    Baton Rouge, Louisiana
    Oh thats so purdy. I have a Gen V in my 2007 GP GT. Whats yours in.
  5. #5 Re: Gen V I polished
    Apr 2009
    Wausau, Wisconsin
    How much you charge?
  6. #6 Re: Gen V I polished
    Jan 2009
    Grand Rapids, MI
    I started with some sanding rolls and a die grinder to knock down some of the casting on the blower. Next bought some greaseless compound from Eastwood. I bought the 4pk kit that came with 80,120,220 and 320 grit. To get in all the tight corners I used a dremel with sanding drums. I took a 1/8 drill bit and cut a notch down the center of it to use in my dremel. Then I cut some 320 & 600 grit sand paper into small pieces and wrapped them around my modded drill bit to finish off the tight areas. Next I wet sanded the entire thing with 600 & 1000 grit to get things smoothed out. Now comes the part that makes you smile. There are 3 different compounds I used for the polishing. Some people say not to use the black compound but I did and had good results. After the black I cleaned the sc off with brake parts cleaner and then polished with the brown compound. I was using my dremel with a flex shaft and polishing wheel to get in the tight spots and I used my Dewalt
    drill with a polishing wheel to do everything else. Make sure you use a new wheel with a different compound. Next I used the white compound with a softer wheel. The final step was a Mothers power ball and Mothers aluminum liquid polish.
    That's a quick write up of the polishing process. SC are a real time consuming piece to polish because of all the corner, curves, ect. If you plan I doing this yourself make sure you have enough time and patience.
    Before Gen V
  7. #7 Re: Gen V I polished
    Apr 2009
    stockton ca
    Seeing as I have a spare blower sitting on a self in the garage might aswell try polishing it And building my patients level for such things
    When i swapped the old one for the one that in my car now i just hit it with a paint stripping wheel to knock the oxidation off and that seemed like a lot of work lol
  8. #8 Re: Gen V I polished
    Aug 2008
    Long Island, New York
    looks mint. if i had an extra blower, and a polishing wheel i would do this.
  9. #9 Re: Gen V I polished
    Jersey
    wanna do mine?
    16' wrx sti- stock
  10. #10 Re: Gen V I polished
    SE Level Member basshead42's Avatar
    Toledo, OH
    damn thats sweet!
    2000 GTX--3.4 pulley, MSD wires, NGK Iridium plugs 2 ranges colder, 180* Tstat, U-Bend delete, DHP 1.0 PCM, Ram-Air, headers are next!
  1. polished------->painted
    By Kool Karl in forum Tires & Wheels
    Last Post: 01-14-2009, 12:08 AM
  2. polished S/C
    By gtpinsc in forum Visual/Body Modifications
    Last Post: 12-26-2008, 12:24 PM
