Thread: disk break question
Results 1 to 11 of 11
  1. #1 disk break question
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    if i paint everything other then where the break pads run will the disks still be able to get ride of heat? i dont want them to overheat because of something that i did. im just wondering because im replacing all four disks. thanks for the help
    silver 2003 Grand Prix GT List is on it's way to be updated
  2. #2 Re: disk break question
    Banned - Busted For Scamming
    Feb 2009
    paint the rotor hats and you will be fine. The dissipation happens where the rotors are vented.
  3. #3 Re: disk break question
    paint everything. the pads will wear off where they sit, who cares if you get a little there.
  4. #4 Re: disk break question
    Nov 2008
    thanks guys i figured that is what youd say i just wanted to make sure before i painted 120$ worth of disks. thanks again
  5. #5 Re: disk break question
    TDCRacing
    Guest
    Yep like stated you should be fine.
  6. #6 Re: disk break question
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    be sure to use high temp paint
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  7. #7 Re: disk break question
    Nov 2008
    the high temp paint that i got is good up to 500 degrees. that should be good enough shouldnt it? it is caliper paint so i figured it should be good
  8. #8 Re: disk break question
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    500° should be fine.
    Now let me know when you get your rotors to mid high 600° like mine
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  9. #9 Re: disk break question
    Nov 2008
    how long does a paint job normally last on these. i know there are factors like paint quality and enviorment but i live in iowa and i put three coats on. its a duiplacolor product if that helps. i just kind of want a gestament. thanks guys
  10. #10 Re: disk break question
    TDCRacing
    Guest
    3 years.
  11. #11 Re: disk break question
    Feb 2009
    powdercoat
  1. What did I break?
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2009, 02:22 AM
  2. help me break rules!
    By Red97GPGT in forum Off Topic Discussion
    Last Post: 05-05-2009, 12:32 PM
  3. Break in oil
    By Stu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-19-2009, 10:22 PM
  4. GXP break upgrade
    By carl06GT in forum Brakes/Suspension/Chassis
    Last Post: 02-26-2009, 08:39 PM
  5. break job help
    By reinke in forum Brakes/Suspension/Chassis
    Last Post: 11-17-2008, 08:42 PM
