Thread: Door Panel Repair
Results 1 to 5 of 5
  1. #1 Door Panel Repair
    Dec 2021
    Nampa Idaho
    Chats
    Hello,
    I am currently restoring a 97 SE. I Am finishing a complete interior swap with a charcoal vinyl interior from a 2000 GT. One question is; Has anyone figured out what to do about the crumbling brittle trim pieces that hold the vinyl to the top of the door panels? They seem to shatter if you breathe on them which makes it difficult for junk yard finds. When you think you found a good one, good luck getting it out in one piece... And you cant just leave them off because the vinyl will peal up off the door panel over time. Any suggestions would be welcome !
    Thanks,
    Derek
    Fixxer Automotive
  2. #2 Re: Door Panel Repair
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Chats
    25
    see if you can find something simliar here
    McMaster-Carr
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: Door Panel Repair
    Dec 2021
    Nampa Idaho
    Chats
    That's Perfect! Thanks!
  4. #4 Re: Door Panel Repair
    Mar 2018
    NY
    Chats
    I'm in the same place myself. 3 out of 4 of the brittle top door moldings are broken on mine. I think one of the back ones is completely missing. Its annoying because the leather at the top of the door just kinda flaps around. I'd rather find replacement moldings than trying to glue the leather to stay in place.
    Let me know which one you buy and how it works FixxerAuto, I'm likely to buy the same ones.
  5. #5 Re: Door Panel Repair
    St. Louis
    Chats
    Maybe try the edge guard stuff the guy is talking about/shows in this thread? Never tried it myself but mine could use some new trim too so I might give it a go.
    Interior Door panel plastic channel along window [SOLVED] : General Chat
  1. 2001 Rocker panel repair question
    By bing98 in forum General Tech Discussion
    Last Post: 06-23-2017, 08:15 AM
  2. How To Remove Door Panels/Replace Door Panel Clips
    By SubwayGuy in forum How To Write-Ups/Tech Tips
    Last Post: 05-28-2016, 02:43 PM
  3. Rocker panel rust repair
    By natethegreat in forum Visual/Body Modifications
    Last Post: 09-25-2012, 10:48 PM
  4. How to repair your door panel trim
    By JesseBranham in forum How To Write-Ups/Tech Tips
    Last Post: 07-25-2012, 08:11 PM
