Thread: painting the wide black moldings between front and back door ,on side of car
Results 1 to 6 of 6
  1. #1 painting the wide black moldings between front and back door ,on side of car
    Feb 2016
    North Carolina
    On my 2002 4 door GP what is the GM color paint used on these moldings ,same sheen ,etc. It is a black. Is it available in a spray can ,from who. ? Any hints on me doing these myself ,they easy to remove ,how should I clean them before painting ,overall prepping them. any tricks. ? Is primer needed ? If so ,what primer should I use ? How should I paint them , the main color , a number of light coats or one or two heavy coats ???
    I am not a painter ,so you know.
    Al
  2. #2 Re: painting the wide black moldings between front and back door ,on side of car
    GT Level Member mguzzo's Avatar
    Buffalo NY
    I used krylon gloss black as basecoat then topped with a clear coat. To remove them you have to pull out the window weatherstripping and access the screw that holds it to the door. wet sand with 600 grit to prep, lay down primer then color and clear.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  3. #3 Re: painting the wide black moldings between front and back door ,on side of car
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    I don't see the 97-03 sedan listed, but maybe you could email them and make sure. It's a temporary solution, but considerably easier than disassembling the doors.
    Vinyl Films & Wraps | Dash Kits | Window Tint | Light Tints | Rvinyl
  4. #4 Re: painting the wide black moldings between front and back door ,on side of car
    Feb 2016
    North Carolina
    Thank You,I'll E-mail them.
    Al
  5. #5 Re: painting the wide black moldings between front and back door ,on side of car
    Feb 2016
    North Carolina
    Rvinyl responded quick,they do not have them. They suggested buying a sheet of vinyl and cutting and forming them myself.
    Al
  6. #6 Re: painting the wide black moldings between front and back door ,on side of car
    Buffalo NY
    IMHO you're better off removing and refinishing with fresh paint and clear for the following reasons:
    1. they are not hard to remove
    2. you can sand and prime to remove any rust. wrapping will trap moisture and cause further rust
    3. You can change color if you want to (say an argent gray instead of black)
  1. Replies: 5
    Last Post: 05-26-2016, 08:55 PM
  2. 2004 grand prix BLACK front pass side door
    By xx99gtpxx in forum Wanted To Buy - Parts
    Last Post: 11-25-2015, 05:47 PM
  3. Painting window moldings
    By luckyg817 in forum General Grand Prix Discussion
    Last Post: 03-22-2014, 12:06 AM
