Thread: 9007 bulbs
Results 1 to 18 of 18
  1. #1 9007 bulbs
    SE Level Member Slueth66's Avatar
    Nov 2008
    Iowa
    whats the best 9007 bulb without going hid?
  2. #2 Re: 9007 bulbs
    Apr 2008
    Chillin at the Beach , VA
    Silverstars
  3. #3 Re: 9007 bulbs
    Jersey
    I just switched to silver star ultra brights from 6000k HID's, Imo they are an f-ing joke for the money you pay, only a little better than stock but not enought to spend $60
    16' wrx sti- stock
  4. #4 Re: 9007 bulbs
    TDCRacing
    Guest
    If you want a true HID look go with the nokia's. They are a blue buld and look JUST like HID's. Just not as bright.
  5. #5 Re: 9007 bulbs
    Jersey
    If you get Nokia's make sure you get extra's they are nice but my headlight and foglight Nokia's blew out in 2 months. Im convinced their isn't a decent 9007 bulb to replace the stock ones with.
    Below is a pic with Nokia blue headlight bulb, and Nokia yellow fog light bulbs
    16' wrx sti- stock
  6. #6 Re: 9007 bulbs
    TDCRacing
    Guest
    So you have had some too? I never owned them but knew a buddy that had them i his jeep. I know his lasted longer than that but not sure how much longer.I can't say.
  7. #7 Re: 9007 bulbs
    Jersey
    yeah its too bad because i did like the way they looked.
    16' wrx sti- stock
  8. #8 Re: 9007 bulbs
    GTX Level Member Warhellride's Avatar
    Norfolk, VA; originally from NH
    The blue tinted bulbs may be whiter, but they're not brighter. The blue coating makes them look whiter/bluer by blocking some of the light, which reduces the output.
    As far as I know, the Philips Xtreme Power +80 is the best 9007 bulb out there. I have the Philips VisionPlus +50, which are one step below the Xtreme +80. These bulbs achieve higher output and a whiter color through more precise construction and different gas mixtures, not through blue coatings. The VisionPlus +50's are almost as white as Silverstars (it's hard to tell the difference even when viewing the two side-by-side) and are noticeably brighter. I can only assume the Xtremes are even brighter still.
    Also, at $39, the Philips Xtremes are cheaper than the $60 SilverStars 99prixgt mentioned above.
    2004 Mercedes-Benz CL55 AMG
    2002 Redfire Metallic Grand Prix GT Coupe (sold after 141,754 miles)
  9. #9 Re: 9007 bulbs
    Jersey
    the whiter the bulb the more you will see.
    16' wrx sti- stock
  10. #10 Re: 9007 bulbs
    Nov 2008
    Iowa
    i ordered some philips extreme power. from what i hear there not bad. At least hopefully
  11. #11 Re: 9007 bulbs
    GT Level Member BackInBlack's Avatar
    Vermont
    Blue bulbs are WORTHLESS. Get yourself some CLEAR GE NightHawks and a relay harness. Can't be beat other than projectors/HIDs.
    Silverstars are too expensive and have 1/2 the life of regular bulbs. If you overdrive them with the harness, expect a 3-6 month life...
    The GPs are long gone...
  12. #12 Re: 9007 bulbs
    Nov 2008
    Iowa
    whats the relay harness do and how do you install one? im guessing it will supply the bulbs with more power
  13. #13 Re: 9007 bulbs
    Vermont
    See my web site...
  14. #14 Re: 9007 bulbs
    Nov 2008
    Iowa
    i have but i dont fully understand the concept of using the old 9007 bulb and the wiring diagram you drew up. can you pm me with more info?
  15. #15 Re: 9007 bulbs
    Dec 2008
    Lawndale, CA
    You can always buy a 9007 relay harness. Check ebay for a 9007 relay harness. Something like this.
    Heavy Duty Headlight Wiring Harness with relays increases voltage over stock wir suvlights.com HEADLIGHT WIRING HARNESSES & WIRING KITS
  16. #16 Re: 9007 bulbs
    Aug 2008
    Long Island, New York
    hmm i like PIAA bulbs. on my last gtp i go their bulbs in my foglights and they made a huge difference. Im not sure what im gonna do this time. maybe an HID kit or ill buy some PIAA's.
  17. #17 Re: 9007 bulbs
    Vermont
    The old 9007 bulb base just acts as a connector to interface with the stock car wiring without damaging the car. It is never a good idea to cut into exterior car wiring.
    Basically, the original headlamp wiring drives a control relay, and the control relay switches the battery power to the new lamps.
  18. #18 Re: 9007 bulbs
    Nov 2008
    Iowa
    so whats the point of the junkyard bulb socket? when it comes to this electrical crap i suck. i need more pictures than whats on your website. sorry for being a hassle. or maybe just more detailed instructions that are step by step, almost like spoon feeding a crying baby.
  1. 99-03 grand prix 8000k 9007 hid conversion kit
    By $03gp/gt$ in forum General Tech Discussion
    Last Post: 11-16-2008, 11:21 PM
  2. Dic Bulbs
    By J_Ferguson in forum General Tech Discussion
    Last Post: 10-21-2008, 06:07 PM
  3. i need bulbs
    By bb52190 in forum Off Topic Discussion
    Last Post: 08-24-2008, 02:40 PM
  4. Fog bulbs
    By Tig in forum Visual/Body Modifications
    Last Post: 05-17-2008, 02:07 PM
  5. fog bulbs
    By Toasty in forum General Tech Discussion
    Last Post: 03-26-2008, 10:23 PM
