Thread: Spyder halo
Results 1 to 20 of 20
  1. #1 Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I am trying to align my Spyder halo headlights. They have a weird angle to them. Up/down and left right can be adjusted but this damn angle. Does anyone have experience with these or know how to adjust this?
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Spyder halo
    Oct 2014
    portland oregon
    I do have experience with these and all and all your hosed lol.
    I got mine decent by adding washers between the mounting tab and the body.
    I also added some 1/2 inch foam backer rod from home depot under the light to keep them from bouncing around..
    All and all these lights are frigging annoying but look cooler then stock imo
    Sent from my SM-N920V using Tapatalk
  3. #3 Re: Spyder halo
    Antioch, IL
    Looks like the projector were not even leveled
    2009 Challenger SRT8
    Expert at being gay.
  4. #4 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yeah the leveling is crazy. I have a warranty set on the way so hopefully those are better. If the next set sucks as well I may try what wow said. Either that or get my $220 back and use the brand new smoked ones I have. I prefer the halo look though. :/
  5. #5 Re: Spyder halo
    Antioch, IL
    Best defense though the 04+ after market lights just plain suck, retro and be happy
  6. #6 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I’m not familiar with the retrofit. Isn’t that basically turning stock housings into Halos? If so do you think there is a way to straighten these lights out?
  7. #7 Re: Spyder halo
    Antioch, IL
    retro is putting real hid projectors into any headlight housing
    to straighten out those projectors you have to take it apart, might as well have real projectors to swap out then
  8. #8 Re: Spyder halo
    Jul 2010
    Coquitlam,BC,Canada
    I believe doing a retro on the Spyder's is even more challenging than doing it to stock headlights.
    Spyder Headlight Retrofit/Redesign
    But I still support doing this.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Well if the warranty set is bad like I suspect I will make them refund the money and maybe do a real retrofit?? I take it there isn’t any already made projector housings that are any good for the 04+ crowd is there? Most of the tutorials I find are for Gen II.
  10. #10 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Well the spyder retro didn’t go so well. I decided to retro an aftermarket set. I blew through it quickly and all was going great, everything aligned and set with epoxy. Well the Acme Super H1s do not allow the cover to go back on. The bi-xenon motor and projector sticks out too far. I have a projector lens that sits right on the reflector bowl without and space. Will that be ok or do they require a certain amount of space to function properly?
  11. #11 Re: Spyder halo
    Jul 2010
    Coquitlam,BC,Canada
    Not sure if space is required, but I had quite a bit (Mormito 5.0 projectors).....
    [IMG]http://chrisb.users.superford.org/Gr...trofit_039.JPG[/IMG]
    [IMG]http://chrisb.users.superford.org/Gr...trofit_055.JPG[/IMG]
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  12. #12 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    The 07 GP housings seem to be narrow. I’ll try to fabricate something I guess
  13. #13 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Not really much I can do with these. It sucks that there isn’t a good aftermarket solution for these cars
  14. #14 Re: Spyder halo
    Jul 2010
    Coquitlam,BC,Canada
    Home
    Classy does good work. The images in his gallery might help you out.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Yeah he has some awesome looking retros! Unfortunately he doesn’t have pics of the process or which parts he used.
  16. #16 Re: Spyder halo
    Antioch, IL
    Why would he, he is a business. I sent him all the parts and he assembled them for $!50 years ago, best thing ever.
  17. #17 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Definitely. I did not expect him to at all.
  18. #18 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I finished my “first” completed retrofit. I only did the low beam side due to budget. It’s not the cleanest retro but functional. I used the Acme Super H1 Bi-Xenon, mini Gatling black shroud and a profile pivot ring.
  19. #19 Re: Spyder halo
    Jul 2010
    Coquitlam,BC,Canada
    Where'd the pics go? Looked good from what I saw yesterday. And now you will have some killer light output.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  20. #20 Re: Spyder halo
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I can see the pictures. I’m not sure what happened.
    Overall I am very happy with them. The light output is great and the profile pivot switchback is cool. The brights are crazy bright. The things I don’t like is I can see the mounting wire for the halo and some marks of the putty epoxy on the shroud. For my first time I am ok with it.
  1. Dim Halo rings [Spyder]
    By themantis in forum General Grand Prix Discussion
    Last Post: 03-28-2016, 02:43 PM
  2. Spyder halo problems
    By Brycejhnsn100 in forum 04+ Specifics
    Last Post: 03-10-2015, 01:30 PM
  3. spyder halo question
    By InsaneGTP in forum Introductions/Noob Questions
    Last Post: 05-03-2014, 05:28 PM
  4. HELP!!!! spyder led halo install
    By cooper25 in forum 5.3L V8 (LS4)
    Last Post: 09-28-2013, 03:04 PM
  5. spyder halo
    By Matt Palm in forum Visual/Body Modifications
    Last Post: 05-23-2012, 08:05 PM
