Thread: I found the fitment problem with Spyder tail lights (6th gen)
Results 1 to 5 of 5
  1. #1 I found the fitment problem with Spyder tail lights (6th gen)
    Mar 2015
    Connecticut
    Mine is a 2001. I expect the same is probably true for other '97-'03 Grand Prix.
    I bought the Spyder tail lights because my OE ones were hazy, cracked, leaking water, blowing bulbs frequently, and I didn't like the OE appearance that much.
    When I went to install them, I found it was difficult to get them to go in, and once seated as far as they would go, there was a significant gap below them.
    I'd read some people widened the mounting holes in the body, so I tried that on one side, but it made no difference.
    Then I looked at the tail light, and the body, and found the problem by where paint had rubbed OFF the body, ONTO the new tail light.
    The Spyder tail light is shaped differently than the OE. There's one corner behind a reflector that sticks too far inward, and touches the body.
    You can try filing off the corner, but it doesn't appear that would allow enough clearance. The solution seems to be to push in the body where the tail light housing touches.
    Up to you how low tech or high tech you want to do this. Smack it with a hammer because nobody will see it, or do more complicated body work.
    I have photos but can't upload because my quota is so small, and I don't see a way to delete existing photos. Anybody know what's up with that?
    Anyway, without the photos, try putting your Spyders in and rocking them a bit, then remove them and look for the paint marks, and you'll see what I mean. I don't think the mounting holes need to be modified at all.
  2. #2 Re: I found the fitment problem with Spyder tail lights (6th gen)
    Mar 2015
    Connecticut
    First and second image have the area circled where paint rubbed. Third image is OE tail light for comparison.
  3. #3 Re: I found the fitment problem with Spyder tail lights (6th gen)
    May 2012
    lebanon ohio
    When I had my 98 and put those tail lights on I just smacked that spot in with a hammer. Mine did the exact same thing yours are doing. It worked perfectly for me.
  4. #4 Re: I found the fitment problem with Spyder tail lights (6th gen)
    Donating Users gingerdude's Avatar
    Dec 2016
    IL
    I also had to smack both sides with a mallet in the same fashion. I still needed to enlarge the mounting holes on the driver side after. But they fit now lol.
    01 GP SE 3.1
  5. #5 Re: I found the fitment problem with Spyder tail lights (6th gen)
    Jul 2010
    Coquitlam,BC,Canada
    Other than the studs being slightly off, mine bolted up just fine.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. F/s Spyder smoked red l.e.d tail lights
    By Rlugo87 in forum For Sale - Parts
    Last Post: 05-12-2017, 03:37 PM
  2. Spyder Tail Lights Installation
    By fitness94 in forum Visual/Body Modifications
    Last Post: 05-30-2015, 01:22 PM
  3. WTB Spyder Red/Smoked LED Tail Lights
    By MattF in forum Wanted To Buy - Parts
    Last Post: 04-29-2013, 10:46 PM
  4. opinions on spyder tail lights
    By Matt Palm in forum Visual/Body Modifications
    Last Post: 03-24-2012, 03:05 PM
