Thread: hit a deer - need piece to hold headlight assembly in
Results 1 to 3 of 3
  1. #1 hit a deer - need piece to hold headlight assembly in
    Sep 2013
    MI
    Hi all, what's the name or part number of the piece that would hold the headlight assembly in?
    That broke behind the headlight assembly.....
    I think I found it, but not sure if this is it or not...
    GM1041112
    http://www.rockauto.com/en/moreinfo.php?pk=952631&cc=1432256&jsn=476
    Thanks!!!
    Looks like less than half price at Rock Auto!!
  2. #2 Re: hit a deer - need piece to hold headlight assembly in
    St. Louis
    Well, there is actually 2 things that hold the headlight in. There is a bracket that the actual headlight sits in, then there is the entire assembly behind that. That would be the header panel.
    Honestly if you could, I'd hit up a JY. Probably plenty of GP's in there.
  3. #3 Re: hit a deer - need piece to hold headlight assembly in
    Pick N Pull ftw.
  1. RH headlight assembly
    By vailskier3 in forum For Sale - Parts
    Last Post: 05-05-2015, 01:42 PM
  2. 97+ Lens out of headlight assembly
    By Ninny in forum Visual/Body Modifications
    Last Post: 08-29-2013, 01:26 PM
  3. Headlight assembly question I should know
    By buck in forum Visual/Body Modifications
    Last Post: 04-27-2011, 01:02 AM
  4. 02 Headlight Assembly Problem
    By RichardL12 in forum General Tech Discussion
    Last Post: 11-15-2010, 12:38 PM
