Thread: headlights
Results 1 to 7 of 7
  1. #1 headlights
    May 2012
    Canada , Sarnia
    is there a difference from oem to aftermarket in the beam pattern I have some ones I ordered off ebay 2 years ago and put them back in the car with the halogen bulbs and notice the beam pattern on the road is horrible if so I was going to go to get another set of oem headlights or order some I have to redo my retro's soon (install new halos , reaim ) and have to put stocks back in ?
  2. #2 Re: headlights
    Omaha, NE
    Were the headlights you ordered supposed to be OEM replacements, or did you order something else like spyders?
  3. #3 Re: headlights
    May 2012
    Canada , Sarnia
    OEM Replacments think I paid around $90 for them 2 yrs ago
  4. #4 Re: headlights
    Nov 2011
    NY
    All of the aftermarket headlight housings suck... HID's in stock housings can be done, you have to mod the socket holder so the center of the filament is the same as the stock bulbs and the light pattern will be just as bad, but brighter : ). The only option for a better light pattern is doing a retrofit. Spyder's and all the others are a waste of $ in my opinion. I run NEW (not new now) stock housings with HID's.
  5. #5 Re: headlights
    Jul 2010
    Coquitlam,BC,Canada
    Yes, the stock lights suck in these cars. Don't waste time with the bulbs, they don't help.
    Retros are the ONLY way to improve light for us.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: headlights
    May 2012
    Canada , Sarnia
    i got my retro's in now but will be going back to stock to redo my retros with new halos and install projector's in the high beams also and reaim the low beam projector there a tad to high
    how far should your cutoff be on the road in front of you ??
  7. #7 Re: headlights
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by gordster1122 View Post
    This is as best the answer I can give you.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. which headlights to get?
    By Kcgp in forum Introductions/Noob Questions
    Last Post: 05-28-2013, 05:03 PM
  2. Headlights
    By Cenon in forum General Tech Discussion
    Last Post: 10-25-2012, 08:20 PM
  3. No headlights or dash lights when the headlights are turned on. HELP!
    By steeck1 in forum Audio, Security & Visual Electronics
    Last Post: 06-23-2012, 12:08 PM
  4. ac on headlights off?
    By JimmyJammer in forum General Tech Discussion
    Last Post: 08-21-2010, 06:07 AM
  5. Need new headlights
    By maddog39 in forum Visual/Body Modifications
    Last Post: 09-29-2009, 07:04 AM
