Thread: What is the paint code for the gray section of the front bumper?
Results 1 to 20 of 25
  1. #1 What is the paint code for the gray section of the front bumper?
    GT Level Member WickedGoat's Avatar
    Dec 2014
    Missouri
    I can't seem to find out the paint code for the dark gray section of the lower front bumper any where. I am going to remove, sand down and paint my front bumper and I was going to try and keep the gray section. I guess I could paint the whole bumper black but then the rear bumper would kinda be out of place. Thoughts? Or any recommendations on the gray?
    2014 Chevy Impala LTZ Limited -- Silver/Black, Grand Prix replacement
    2004 Pontiac GTO -- my garage queen
    2004 GMC Yukon SLT -- wife's daily driver
  2. #2 Re: What is the paint code for the gray section of the front bumper?
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    You can't see the front and rear bumper at the same time..... thats probably not very helpful huh?
    I had an aftermarket rear bumper on my 01 and it didn't have the grey or the lettering it was just solid blue. I never even noticed until I had to replace it and had the one I got from the junkyard side by side with it.
    I went NA when a whore left -$300 in my bank account.
  3. #3 Re: What is the paint code for the gray section of the front bumper?
    Dec 2014
    Missouri
    No, you can't see them at the same time, but...
  4. #4 Re: What is the paint code for the gray section of the front bumper?
    SWPA
    If its anything like the gray parts on 04+ then it isn't painted, its just the color of the extruded plastic.
  5. #5 Re: What is the paint code for the gray section of the front bumper?
    I know it's painted on 97-03 cars and I have no idea on the paint code. Likely not something you'll be able to find without a body shop helping you out. They paint won't be cheap either.
    I'd just find a standard GM gray paint from napa or wherever in the duplicolor and paint it with that.
  6. #6 Re: What is the paint code for the gray section of the front bumper?
    Jan 2014
    AR
    Most folks would probably go ahead and shoot the whole bumper black then get some good rattle can semi-gloss dark grey metallic trim paint like SEM to do the accent. Spray touch ups later are easy that way. Finding the right code is kinda a dead end by the book and computer but I know I've seen it posted here somewhere. Seriously, most painters would walk out to the car with a correct year chip chart of GM accent colors and pick whichever one looks closest.
  7. #7 Re: What is the paint code for the gray section of the front bumper?
    GrandPrix Junkie
    St. Louis
    Give this thread a read and see if it helps?
    http://www.grandprixforums.net/threa...ont+paint+code
  8. #8 Re: What is the paint code for the gray section of the front bumper?
    Dec 2014
    Missouri
    Thank you for the replies everyone. Fordman, I opened your thread and went to open the link you provided and it comes up as being hosted by Host Gator. If you know of a different way to get to the website, let me know. Thanks in advance...
  9. #9 Re: What is the paint code for the gray section of the front bumper?
    GrandPrix Junkie
    St. Louis
    Sorry about that. Check out this link:
    http://www.paintscratch.com/touch_up...r)-WA6246.html
  10. #10 Re: What is the paint code for the gray section of the front bumper?
    Dec 2014
    Missouri
    Quote Originally Posted by FordMan77 View Post
    Awesome my friend... Thank you...
  11. #11 Re: What is the paint code for the gray section of the front bumper?
    Apr 2011
    North Los Angeles
    Is there anyway to properly sand down that plastic part on an 07 gp? I'm not sure mine has paint or not, it is beat up by the sun, was thinking of sanding and adding a uv resistant clear coat.
  12. #12 Re: What is the paint code for the gray section of the front bumper?
    SWPA
    Get some Mother's Back to Black and use it. It works wonders.
    I was trying to find a pic of my pieces after the BtB but must not have taken any.
  13. #13 Re: What is the paint code for the gray section of the front bumper?
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by steelholder View Post
    If you are talking about the trim, look into solution finish.
  14. #14 Re: What is the paint code for the gray section of the front bumper?
    you wet sand with 2000-2500 grit paper to scuff the old paint, then use prep spray /wax and de greaser to get it clean.
    mask off and paint it up, then clear coat it. you can leave it as is, or wet sand the clear coat and compound it to a nice shine.
  15. #15 Re: What is the paint code for the gray section of the front bumper?
    Apr 2011
    North Los Angeles
    How long does it last?
    How long does it last. Does it work on the interior trim that's been dulled?
    Is there a more common paint/color that can be used? Besides the one on link
  16. #16 Re: What is the paint code for the gray section of the front bumper?
    duplicolor is sold at parts stores, the cap is pretty much the color you'll have when its dry. they have gm color names on the cans. find a few silver to greys and ask to see if they match up up close, most stores will let you run out side real quick and check.
    ive used it on both my bumpers. full repaints. mine was rather easy tho, its black. i used gm metallic black.
  17. #17 Re: What is the paint code for the gray section of the front bumper?
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    WA6246 is the actual paint code.
  18. #18 Re: What is the paint code for the gray section of the front bumper?
    Dec 2008
    Lawndale, CA
    Mothers Back to Black will last about a month tops before it needs to be reapplied. That is with cleaning the trim with either an all purpose cleaner or Mother Back to Black Trim Cleaner. It's meant for exterior plastic trim. This is pretty much the longevity of most trim products available over the counter.
    Are you looking for interior products that are available over the counter?
  19. #19 Re: What is the paint code for the gray section of the front bumper?
    Apr 2011
    North Los Angeles
    Quote Originally Posted by The Guz View Post
    yes if you know of one, there seems to be two different textures on the door/dash areas one seems to be vinyl and the other plastic right? Ive never found anything that brought the black back.
    For the outside bumper plastic piece it may be cheaper to sand and paint or add sealer. I enjoyed doing my headlights in a similar fashion and they've looked new for half a year now.
  20. #20 Re: What is the paint code for the gray section of the front bumper?
    Apr 2011
    North Los Angeles
    ill take some before and after pics and maybe post a diy if it comes out good,thats if there isnt one already up.
  1. Front Bumper Paint Scratch...
    By Lowdown112 in forum Visual/Body Modifications
    Last Post: 12-30-2012, 12:14 AM
  2. Need paint code (front bumper, the gray color)
    By gpbastard in forum Visual/Body Modifications
    Last Post: 05-08-2010, 08:48 AM
  3. Remove paint off front bumper
    By Frank217 in forum Visual/Body Modifications
    Last Post: 04-08-2010, 10:40 PM
  4. Front and Rear Bumper (Paint)
    By HOPPY in forum How To Write-Ups/Tech Tips
    Last Post: 11-10-2009, 04:22 PM
