Thread: Best injectors to use?
Results 1 to 10 of 10
  1. #1 Best injectors to use?
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    Right now I am still building the car and have 60 pound injectors that are going to go in. I talked to a few others and Sal ran out of fuel at the top end of a run and he is running 90's. ZZP has the 160's but if I could get away with a 120# that would work I would want to go with those. Has anyone really ran anything that large and ran into problems going out quickly?? Open to any advice!
  2. #2 Re: Best injectors to use?
    Kemmerer, Wyoming
    I'm not sure what the answer is to your question, but sal's car was 500+ at the wheels, not sure how much power you are going for.
  3. #3 Re: Best injectors to use?
    Jun 2014
    United States
    I want to get 500 at least
    Sent from my SM-G900P using Tapatalk
  4. #4 Re: Best injectors to use?
    Kemmerer, Wyoming
    let us know how it goes, I have no idea what you need, my 42.5's are sufficient for my build.
  5. #5 Re: Best injectors to use?
    80's seem to get the job done.
    But without anything more than "I want 500 horsepower"...
    Your post is pretty vague.
  6. #6 Re: Best injectors to use?
    Jun 2014
    United States
    Stattama T67 setup, full IC, 150# springs, Bullyflo Heads, st5 cam, double roller timing chain, not much but ac delete, aem e85 high flow fuel pump. There is probably things I am missing.
  7. #7 Re: Best injectors to use?
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    When I ran out of fuel I was using 80lb injectors and a Racetronix 255 pump. As mentioned I was over 500 at the wheels.
    I now have a Racetronix 485 pump and 95 lb injectors and not even close to maxing them out.
    Go with 95's. Also get the racetronix fuel pump rewire kit.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  8. #8 Re: Best injectors to use?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Racetronix makes a 485 pump for these cars?
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  9. #9 Re: Best injectors to use?
    Feb 2008
    NY
  10. #10 Re: Best injectors to use?
    Jun 2014
    United States
    Sweet thanks a lot for that! I thought it was your 90s you maxed.
  1. 42.5lb injectors
    By gambler87 in forum Wanted To Buy - Parts
    Last Post: 02-09-2014, 09:05 PM
  2. Injectors
    By rryanwswan69 in forum Wanted To Buy - Parts
    Last Post: 01-10-2014, 02:04 PM
  3. Injectors
    By jdwyat in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-27-2010, 01:00 PM
