Thread: Pushrods and lifters?
Results 1 to 5 of 5
  1. #1 Pushrods and lifters?
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    I am building my turbo but just wanted a few others opinions on what lifters and length of pushrods I should get.
    I am going with a st5 cam and 150# springs if that matters. I planned on going with the OER lifters but if the ls7 has a better combination with pushrods I would rayher go with that. Just looking at your opinions on what I should run.
  2. #2 Re: Pushrods and lifters?
    Nov 2012
    Erlanger, KY
    OER lifters only good if got adjustable rockers...
    LS7/Stock lifters are just fine.
    Pushrod wise, I always recommend to measure and get custom set cut to get perfect lengths for your setup.
    2001 Turdbo Grand Prix GTP - 10.41@132
    Videos @ https://www.youtube.com/user/jdredd34
  3. #3 Re: Pushrods and lifters?
    Jun 2014
    United States
    I was told stock or I believe it was 1.6 rockers are good with the st5 im thinking of just staying with the stock unless there is a pretty good difference between thqt and the 1.6
  4. #4 Re: Pushrods and lifters?
    GTP Level Member
    Jan 2015
    Lincoln, NE
    i run stock push rods with LS7 lifters and st5 cam. my stock rockers installed between 1/2 and 3/4 turns. my heads were planned .005" and i run stock gm headgaskets.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  5. #5 Re: Pushrods and lifters?
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    I got a pushrod measuring tool. After having heads cleaned up and cometic MLS gaskets, I needed a slightly shorter pushrod than stock to get the proper preload on ls7 lifters. Definitely would suggest measuring for OE-R lifters since they use only a small amount of preload, so you will probably need shorter ones. ls7 you would probably be ok with stock length if you chose not to measure.
  1. Replies: 28
    Last Post: 03-11-2015, 10:44 PM
  2. wtb 6.95 pushrods
    By REDCRAPGP in forum Wanted To Buy - Parts
    Last Post: 06-26-2014, 07:54 PM
  3. VS Cam..Pushrods/Lifters?
    By Blake71091 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-29-2014, 02:15 AM
  4. Pushrods
    By rryanwswan69 in forum Turbo
    Last Post: 01-16-2014, 04:01 PM
  5. pushrods
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-26-2011, 05:33 PM
