Thread: Turbo Project- Posting throughout the entire build
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 61
  1. #1 Turbo Project- Posting throughout the entire build
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    I have more photos yet can't add them any ideas? Ive seen threads with more than two photos haha.
    I am putting a Turbo into my 2000 Grand Prix, it was my first car and is in pretty rough shape. I hope to get it to an 11 second car if possible, watch the pictures as I attempt to get there.
    ~~Mods going into the car~~
    Stattama T67 Turbo kit
    E85 Fuel Pump
    65# Fuel Injectors
    15# Bottle of Nitrous, proton plus shots going from 35-250hp. (possible)
    Still deciding on other modifications and best way to do them which are mostly the heads, springs, timing chain etc.
    Turbo Project- Posting throughout the entire build Attached Images
  2. #2 Re: Turbo Project- Posting throughout the entire build
    hope you got some bucks for a trans if you want to go 11s on turbo e85 and bottle........
  3. #3 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Yes I plan to get a trans built as well. This isn't going to be a cheap hobby found that out even after buying a pillar and gauges haha.
  4. #4 Re: Turbo Project- Posting throughout the entire build
    I always use a photo sharing website to link the "direct" link of the picture to here.
  5. #5 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Just put links up instead? I used the "Insert Image" Button but only allowed me to have two photos. Ill just do the direct button.
  6. #6 Re: Turbo Project- Posting throughout the entire build
    Like from photobucket, paste the URL.
    I've never linked photo's from the computer itself.
  7. #7 Re: Turbo Project- Posting throughout the entire build
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    Ru gunna run a wet kit or dry ? and I would go bigger than 65lb injectors
  8. #8 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Its a wet kit, I got the injectors with a kit I bought with the turbo so it wasn't to bad, if they dont perform high enough I will upgrade to the 80#s
  9. #9 Re: Turbo Project- Posting throughout the entire build
    May 2012
    Where winter never ends
    use [img] url to img [/img] to post images.
    2000 Regal - Winter Beater
  10. #10 Re: Turbo Project- Posting throughout the entire build
    Arizona
    If it's wet the injector size should be adequate, your biggest obstacle is f the pressure drop while using the nitrous off the fuel rail. Upgrade your pump to something adequate for boost and nitrous
  11. #11 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    The aem e85 fuel pump you think wont be big enough? ??
  12. #12 Re: Turbo Project- Posting throughout the entire build
    Arizona
    That's 320lph i would test it out on boost, install a fuel pressure gauge and check for drop off at wot. start off on n20 with a small 50 shot. And go up till you see your fuel pressure drops
  13. #13 Re: Turbo Project- Posting throughout the entire build
    Oct 2012
    Albany, NY
    I run a 450 walbro in stock canister. Maybe that's something you can look into
  14. #14 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Thanks ill look into it! Hopefully I can get most of this done soon. The track opens in May and I would like to have it fully tuned before that, I highly doubt it but the chances are there.
  15. #15 Re: Turbo Project- Posting throughout the entire build
    Oct 2012
    Albany, NY
    There's actually a thread on how to make a 450lph pump work In stock canister that snowflake made. That's what I'm running and its a stout setup.
  16. #16 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Ok I have gotten a little ways just haven't gotten far enough for an actual update. I do have a few questions for you guys though
    I went with the ST5 cam and it says on the ZZP website with recommended things, one is the lifters. Should I go with the OER lifters or LS7? If you could please kind of back it up. With the lifters being upgraded should i upgrade the rockers as well? They say stock or 1.6 would be the best, if I can get the same performance on stock I won't spend the extra money.
    Also on their website they recommend titanium retainers yet they only sell steel, does SummitRacing sell the retainers, are they specific to the engine or just piston size?
  17. #17 Re: Turbo Project- Posting throughout the entire build
    Oct 2012
    Albany, NY
    I run ls7 lifters and stock rockers.
  18. #18 Re: Turbo Project- Posting throughout the entire build
    Bastard Reptile's Avatar
    Kansas City, MO
    Intense Racing offers titanium retainers.
  19. #19 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by 98ICLovinVet View Post
    this thing should not need the bottle to run 11's
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  20. #20 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Neb, do you think mid 11 or higher 11? I dont plan to use the bottle anymore I think I dont want to blow anything
  1. Grand prix project build
    By forcedinduction in forum Introductions/Noob Questions
    Last Post: 06-04-2013, 09:17 PM
  2. Project Z38. Fosho99/Nvsridez Build
    By nvsridez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2013, 07:52 PM
  3. project build
    By 98buicksupercharged in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2012, 03:06 PM
  4. Project 91 Firebird Build Thread
    By Lsick7 in forum Off Topic Discussion
    Last Post: 07-12-2010, 02:31 PM
  5. The new guy: Matto's Project build thread!
    By Matto211 in forum General Tech Discussion
    Last Post: 01-10-2009, 07:47 PM
