Thread: Turbo Project- Posting throughout the entire build
Results 21 to 40 of 61
  1. #21 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    higher 11's but on e85 you shouldnt have too much trouble making over 350+ whp. it will be the L36 bottom end that holds you back i was always scared to turn mine up past 13psi. next thing it will need is some help breathing.
    - 2001 Grand Prix XGT -- 11.21@124MPH
    - 2010 Chevy 2500HD LTZ -- Car hauler
    - 2011 BMW 328i Xdrive -- Wife's Daily
    - 2014 Ford F250 crew cab -- 6.2 liters of ford fail
  2. #22 Re: Turbo Project- Posting throughout the entire build
    SE Level Member Loftus1995's Avatar
    Jun 2014
    United States
    How could I improve the breathing? And is there anything I could do for the bottom end?? I have a supercharger motor I could take parts out of but I doubt the bottom ends would be much different. I was also just on the intense racing website and they have ported lower intakes is that something I should invest in or is there not that big of a difference?
  3. #23 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    the bottom end of the supercharged motor is lower compression then the N/a motor. the heads cc's are the same. i would stick a cam, valve springs, timing set in it to improve breathing. ported intake isnt going to make much difference.
  4. #24 Re: Turbo Project- Posting throughout the entire build
    May 2008
    Schuyler, NE
    Just use ls7 lifters. Oer lifters only work well if you have adjustable rockers. No point in upgrading from stock rockers unless you are spending the big bucks on adjistables. Just run stock, and measure your pushrod length.
    I would switch to titanium retainers with 150# springs. I don't really like the Manley retainers that intense sells. Comp cams makes a better retainer.
  5. #25 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    seems like back in the day the thought was the L36 wasnt good for much past 400 WHP before the bottom end would fail.
  6. #26 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    im rocking stock retainers yo!!
  7. #27 Re: Turbo Project- Posting throughout the entire build
    May 2008
    Schuyler, NE
    You have 130# springs though, right?
  8. #28 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Yup! I bought a st5 cam with 150# springs going on the heads, and a double timing chain. GTPpower where can I get the comp cams retainers?? Zzp doesnt sell the titaniums.
  9. #29 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    yeah actually the crow 125# shimmed to 130# should i get 150# pac springs?
  10. #30 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    Quote Originally Posted by Loftus1995 View Post
    well if thats the case you should be well on your way to testing the ability of the L36 to hold power. you shouldnt have any issue making 500 on that valve train and turbo. i hope you bought some head studs as well...
  11. #31 Re: Turbo Project- Posting throughout the entire build
    May 2008
    Schuyler, NE
    Summit racing. Part number:
    cca-772-12
  12. #32 Re: Turbo Project- Posting throughout the entire build
    May 2008
    Schuyler, NE
    Quote Originally Posted by NebTurboST5 View Post
    What rpm does your power start to drop off?
  13. #33 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    about 5900 last time i was on the dyno.
  14. #34 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    500 horse?! Im still looking at things to buy but if I need something I need it haha. Im going to order the retainers and lifters today then I will be looking into anything else I will need
  15. #35 Re: Turbo Project- Posting throughout the entire build
    May 2008
    Schuyler, NE
    Hmmmm. Is your turbo running out of steam?
  16. #36 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    my scans say im running 49lb/minute of air at 6300. not sure how accurate that is its right at the upper edge of what the pt61 is capable of supplying. its at about 60% efficiency so yeah.
  17. #37 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    it should be noted that if you turn it up that high the bottom end probably wont last very long. also, you are going to need a serious transmission
  18. #38 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    Yup I got a transmission build coming real soon, is there anyway I can get the bottom end to last, I only plan to turn it up at the track.
  19. #39 Re: Turbo Project- Posting throughout the entire build
    GTP Level Member
    Jan 2015
    Lincoln, NE
    not really its a rods, pistons issue. just not as strong as the L67
  20. #40 Re: Turbo Project- Posting throughout the entire build
    Jun 2014
    United States
    I was thinking new pistons, zzp is a little pricey but if I can get them soon I may get a set
  1. Grand prix project build
    By forcedinduction in forum Introductions/Noob Questions
    Last Post: 06-04-2013, 09:17 PM
  2. Project Z38. Fosho99/Nvsridez Build
    By nvsridez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-08-2013, 07:52 PM
  3. project build
    By 98buicksupercharged in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-20-2012, 03:06 PM
  4. Project 91 Firebird Build Thread
    By Lsick7 in forum Off Topic Discussion
    Last Post: 07-12-2010, 02:31 PM
  5. The new guy: Matto's Project build thread!
    By Matto211 in forum General Tech Discussion
    Last Post: 01-10-2009, 07:47 PM
