Thread: Need some turbo info.
Page 2 of 7 FirstFirst 1234 ... LastLast
Results 21 to 40 of 122
  1. #21 Re: 500 WHP Pump gas build up (Pic Heavy)
    TDCRacing
    Guest
    Quote Originally Posted by UR LOSN View Post
    I was bummed there are no pics!!!!!
    ALSO VERY IMPORTANT: since you are building your race motor. CRYO the bottomend!!! you will have an even stronger bottomend!!!!
    it will handle whatever you throw at it!
    They will be here soon lol.
    I think i'm going to be going with a stock l26 motor. I can get one for pretty cheap considering it's only got 6000 miles on it.
  2. #22 Re: 500 WHP Pump gas build up (Pic Heavy)
    TDCRacing
    Guest
    Quote Originally Posted by chrisb View Post
    that oil pressure kit from intense i believe its a stock spring with a washer behind it to give it the extra psi. i can messure it and give ya the specs of the washer if you like it should save ya 30 bucks
    oh zzp has that tranny from the turbo impala for sale it has a 1inch chain in it
    Yeah I saw that tranny. Tempting if i already didnt have one.
  3. #23 Re: 500 WHP Pump gas build up (Pic Heavy)
    Apr 2008
    Chillin at the Beach , VA
    I think one major mod that needs to be done is we pull your motor out and stick it in mine. Sounds like it's going to be a good build. I seen a video of a supra lay down 30 ft marks at 80. can't wait to see some pics.
  4. #24 Re: 500 WHP Pump gas build up (Pic Heavy)
    TDCRacing
    Guest
    By the way that transmission that zzp has for sale came out of this car.
    Car had stock heads, stage 4 intense cam and the stattam t67 kit.
    http://www.youtube.com/watch?v=1fVTzRAFdTE
    The traction bar setup on that inpalla is something like what i'm going to have.Something that can be takes off wehn on the street and hidden by the licence plate. A little fab work should take care of that.
  5. #25 Re: 500 WHP Pump gas build up (Pic Heavy)
    Jan 1970
    Maquoketa, Iowa
    Ever think about going E85? Takes more fueling mods but the results are proven, and its still pump gas
    A low mile L26 can be had for a lot cheaper than $1000. I just helped unload one a few weeks ago that cost him $400 with 20,000 miles on it, he's selling the topend parts for a s/c build and about made all his money back. Its going to take less boost to make power over a L32 but you dont have much to work with as far as tuning error on that L26.
  6. #26 Re: 500 WHP Pump gas build up (Pic Heavy)
    Jan 1970
    Maquoketa, Iowa
    Quote Originally Posted by TDCRacing View Post
    YouTube - Turbo Impala Runs 10.06
    I dare ya to ask Matt how many hours of tuning was done on Kalo's impala!
  7. #27 Re: 500 WHP Pump gas build up (Pic Heavy)
    I live here. UR LOSN's Avatar
    Rockford, IL
    The Intense oil pressure kit is not a washer. It has a higher tensioned spring.
  8. #28 Re: 500 WHP Pump gas build up (Pic Heavy)
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    It's worthless is what it is.
    Lumpy Gen 3
  9. #29 Re: 500 WHP Pump gas build up (Pic Heavy)
    TDCRacing
    Guest
    Quote Originally Posted by FoSHO99 View Post
    Why not much tuning error with the l26? So basicly you're saying it's easier to blow up?
    Yeah i have thought about e85 but since this is my dd and there's not many stations around here that carry it...only 1 i belive...other wise i'd go all for it.
  10. #30 Re: 500 WHP Pump gas build up (Pic Heavy)
    TDCRacing
    Guest
    I can only imagine. Although it would be nice im in no way expecting to just slap it on and run 10's lol.
  11. #31 Re: 500 WHP Pump gas build up (Pic Heavy)
    Donating Users chrisb's Avatar
    Bucyrus, OH
    if the intense oil pressure kit is a higher strengh spring then whats the washer for?
    have you thought about using l67/l32 heads and lim from a l36/l26 so you have and extra set of holes maybe a second set of injectors? or maybe nitrous? some kind of alcohol?
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  12. #32 Re: 500 WHP Pump gas build up (Pic Heavy)
    SE Level Member Sinister Drag Designs's Avatar
    Duck call used a ST4 cam from stattama not intense.
    ZZP uses a higher tension spring in there oil kit. Intense uses a small machined washer. Both work fine.
    If you are using a l26/L32 swap the front cover from a L67/L36.
    The newer style cover is a joke when it comes to flow.
    Are you at least going to mod the oil pan gasket for flow to Cyl #4 ?(this will help as much as any cryo treatment you will do to the bottom end)
  13. #33 Re: 500 WHP Pump gas build up (Pic Heavy)
    Jul 2008
    sumter,south carolina
    sounds awesome dude,cant wait to the finished product.
    02 GTP with mods 05 GP for DD
  14. #34 Re: 500 WHP Pump gas build up (Pic Heavy)
    TDCRacing
    Guest
    Quote Originally Posted by Sinister Drag Designs View Post
    Well I don't know anything about the oil pan mod. Care to explain?
  15. #35 Re: 500 WHP Pump gas build up (Pic Heavy)
    You cut out part of the oil pan gasket around the #4 cylinder for better oiling. Ill try and take a picture of one if I can, dont know if we have any already cut in stock.
  16. #36 Re: 500 WHP Pump gas build up (Pic Heavy)
    Donating Users blowfishRus6's Avatar
    g.a.
    my god. my god...
    i still want dibs on the cam and few other goodies
    no whipple???
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  17. #37 Re: 500 WHP Pump gas build up (Pic Heavy)
    TDCRacing
    Guest
    That would be awesome. How would that improve oiling? Would it just help with oil drain back or what?
  18. #38 Re: 500 WHP Pump gas build up (Pic Heavy)
    TDCRacing
    Guest
    Current combo just sold in sig pending monthly payments. Will be ordering some turbo parts soon hopefully.
  19. #39 Re: 500 WHP Pump gas build up (Pic Heavy)
    g.a.
    front cover. what is that???
    its slow.
  20. #40 Re: 500+ WHP Pump gas build up (Pic Heavy)
    g.a.
    valve cover????
    its slow.
  1. Heavy duty scratchs
    By DesQ27 in forum Visual/Body Modifications
    Last Post: 11-06-2008, 10:32 PM
  2. On behalf of SD GTP (pic heavy)
    By Injun #4 in forum Visual/Body Modifications
    Last Post: 08-19-2008, 12:07 AM
  3. The swap-Pic heavy
    By TDCRacing in forum Off Topic Discussion
    Last Post: 07-03-2008, 12:46 AM
  4. a little update for you guys *pic heavy*
    By kyle99gtp in forum Visual/Body Modifications
    Last Post: 05-02-2008, 01:32 PM
