Thread: Turbo
Results 1 to 13 of 13
  1. #1 Turbo
    Nov 2012
    What do you guys think about the holset hx50 to big for a 500whp build?
  2. #2 Re: Turbo
    May 2012
    Where winter never ends
    What other mods do you plan on using to get to 500whp. That is a hard number than most think to achieve?
    2000 Regal - Winter Beater
  3. #3 Re: Turbo
    Nov 2012
    Nstar lq4, L26 uim and lim, L67 ported heads, 130# springs, oer, lifters, st5 cam, double roller, fully built trans,60# injectors, etc.
  4. #4 Re: Turbo
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    What in ur trans ? And what fuel are u gunna be using ? 60s wont be enough for 500whp on e85
  5. #5 Re: Turbo
    Feb 2009
    flintnasty MI
    I trapped 135 (probably like 127 in wbody terms) in my fiero on 60s and e85.
  6. #6 Re: Turbo
    Nov 2012
    My trans is built to handle 800-1000 hp and I am going to 95# injectors so now its time to figure out a turbo that lines up without modifying anything else since I already have a holset hx35
  7. #7 Re: Turbo
    Oct 2012
    Albany, NY
    Whats in the trans ?
  8. #8 Re: Turbo
    Nov 2012
    all hardened parts 7/8 chain upgraded clutches shafts valve body etc
  9. #9 Re: Turbo
    Jan 1970
    Maquoketa, Iowa
    Unless your car is weighing around 2k lbs, the 7/8ths chain is gonna stretch north of 400whp...
  10. #10 Re: Turbo
    Nov 2012
    It should last me til next year I just had the trans built and originally was only going to be about a 450whp but am going bigger
  11. #11 Re: Turbo
    Oct 2012
    Albany, NY
    So ur trans isnt built to handle 800hp , more like 450....
  12. #12 Re: Turbo
    Nov 2012
    Its just the chain otherwise it is good
  13. #13 Re: Turbo
    Oct 2012
    Albany, NY
    7/8 isnt rated to 500whp , itll last some time depending on how u drive , but it will need to be replaced every so often
  1. Replies: 23
    Last Post: 03-26-2014, 02:22 PM
