Hey guys. Im wrapping up the turbo build on my 04 and I have the stock L26 intake on top of the motor. Where do I need to install a vacuum nipple? Im not getting vacuum from that one nipple on top but from what I've heard im not supposed to be.....
A vacuum block still needs a vacuum source.
For my 07 I have an adapter that replaces the map sensor and I run everything from there. I ordered it from ZZP. It would probably be your best bet. You'll have to email them about it though because they don't have it on the website
pull off the upper intake and drill tap the side of your upper pcv housing for a 1/8th npt to nipple fitting.
since your turbo im betting you have an RTV filled PCV valve witht he OEM Oring or the lim blocked off (in either case make sure you get rid of the plastic pcv distribution "J" tube that clips into the UIM gasket carrier...)
all you have to do is tap into that chamber or the backside of the EVAP/Purge solenoid boss and youll be good to go (drill bit/tap would point towards cyl 4, neatly clearing your WG)
