Thread: need to find a vacuum source
Results 1 to 13 of 13
  1. #1 need to find a vacuum source
    SE Level Member Wakeboy1337's Avatar
    Dec 2010
    Fort Pierce, Florida, United States
    Hey guys. Im wrapping up the turbo build on my 04 and I have the stock L26 intake on top of the motor. Where do I need to install a vacuum nipple? Im not getting vacuum from that one nipple on top but from what I've heard im not supposed to be.....
  2. #2 Re: need to find a vacuum source
    back of your intake next to the brake booster line is a nipple for a vac line. its for the hvac but you can tap it if need be.
    see nipple?
  3. #3 Re: need to find a vacuum source
    Dec 2010
    I can't get to it. My waste gate is in the way
    Sent from my SPH-L710 using Tapatalk
  4. #4 Re: need to find a vacuum source
    what line do you need vacuum for?
    vac line is soft and very flexible, you should be able to get it on there and route it safely away from any pipes.
  5. #5 Re: need to find a vacuum source
    Dec 2010
    Need it for my boost controller, wastegate, and bov.
  6. #6 Re: need to find a vacuum source
    thats the only port im aware of. you'll need to get to it some how i guess.
  7. #7 Re: need to find a vacuum source
    Dec 2010
    Ill try an elbow. That's the evaporation port right?
  8. #8 Re: need to find a vacuum source
    that port is where the hvac line should go. or the air flow wont change direction in the car, aka vents, floor, defrost.
  9. #9 Re: need to find a vacuum source
    Dec 2010
    04+ is all electric hvac. they never had vacuum hvac controls
  10. #10 Re: need to find a vacuum source
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    Get a vaccum block
  11. #11 Re: need to find a vacuum source
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    Quote Originally Posted by 1999black3800 View Post
    Get a vaccum block
    A vacuum block still needs a vacuum source.
    For my 07 I have an adapter that replaces the map sensor and I run everything from there. I ordered it from ZZP. It would probably be your best bet. You'll have to email them about it though because they don't have it on the website
  12. #12 Re: need to find a vacuum source
    hes got a port he could run block off off, hes just saying its tight to get to. nothing a pair of long needle nose pliers cant fix in my book.
  13. #13 Re: need to find a vacuum source
    hangover park IL
    pull off the upper intake and drill tap the side of your upper pcv housing for a 1/8th npt to nipple fitting.
    since your turbo im betting you have an RTV filled PCV valve witht he OEM Oring or the lim blocked off (in either case make sure you get rid of the plastic pcv distribution "J" tube that clips into the UIM gasket carrier...)
    all you have to do is tap into that chamber or the backside of the EVAP/Purge solenoid boss and youll be good to go (drill bit/tap would point towards cyl 4, neatly clearing your WG)
    ~James~ Psychotic Gearhead
  1. WTB: MAP sensor vacuum hose or vacuum tees
    By Dschroeter63 in forum Wanted To Buy - Parts
    Last Post: 09-22-2013, 02:23 PM
  2. the retrofit source.
    By HVACgtp in forum Visual/Body Modifications
    Last Post: 12-27-2012, 10:01 PM
  3. Source for aftermarket rubber vacuum fittings (boots)?
    By fju2 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-08-2011, 08:21 PM
  4. What is the source of this noise?
    By abomb55076 in forum General Tech Discussion
    Last Post: 07-15-2011, 11:18 PM
  5. Replies: 4
    Last Post: 06-13-2011, 02:37 AM
