Thread: Valve springs
Results 1 to 14 of 14
  1. #1 Valve springs
    Jan 2014
    East Grand Forks
    Right now Im working with a pt61 turbo with ic on a stock na block... Id like to go 1.9 rockers at some point this summer. And prob some year do a cam again. What pound springs should I run? Ppl say don't go 150 until caming it but ppl say don't go 90s since there is no point. Recs?
    Sent from my SPH-D710 using Tapatalk
  2. #2 Re: Valve springs
    Jun 2012
    south haven mi
    It depends on the cam shift points etc.I wouldnt waste my time on rockers on a set up like that.i would use 90's at at least.ZZP claims the crows can give you 15 horse on the upper end.
  3. #3 Re: Valve springs
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    Don't go rockers if your doing cam because you can't run both. I went with 105's I wouldn't get 90's
  4. #4 Re: Valve springs
    Florida
    ^ You're sort of right, and wrong.
    You can go rockers and cam, it just depends how you're heads are clearanced. For example, my cam with 1.8 rockers would put me at .597 total lift. So I would have to get my heads clearanced to at least .600.
    Turbo car's benefit more from camming then they do from rockers. Most of the highest HP Turbo 3800s run stock rockers.
    So match your valve-springs with the cam setup. I'd run 105's or 150's. 105's if going with a mild cam and shifting around 6k or so. 150's if you're going with a big cam and wanting to shift much higher.
  5. #5 Re: Valve springs
    Jan 2014
    East Grand Forks
    I'm just planning on doing rockers this year as a quick mod. To add that extra boost. I would put in stock rockers if I go cam. I've never had rockers so I just wanna see kinda. Would 105s be a universal spring for rockers and cam? 150s just seem so big. It'll be a dd most likely once a little snow starts melting. Which spring brands are the ones that always break?
  6. #6 Re: Valve springs
    Florida
    If you go with 105's get Crow Cams. Skip the Comp Cams 105s.
    How many times do you want to change valve springs? While 105's will be fine with higher lift rockers and mild cams, there's not much sense in buying 105's if you'll need to upgrade father down the road.
    Are you planning on going with modified stock rockers, or roller rockers?? Turbo car's don't care for roller rockers. Again, why most high HP builds use stock.
    I personally wouldn't run an old stock timing chain/damper on anything other than stock springs. I would go ahead and replace it with a new stock set if going with 105's/90's. Or go up to a roller set.
  7. #7 Re: Valve springs
    Jan 2014
    East Grand Forks
    I would just be going with modified rockers. Not rollers. I guess its not hard to replace springs I was just seeing if any would be universal. As you're saying throw in new timing set. I should just go cam then. Ahhhh. I wanna try rockers tho. Lol
  8. #8 Re: Valve springs
    Florida
    There are people rocking stock timing chains with the modded rockers, though if you start raising the shift points I'd be a little concerned.
    As long as you have access to compressed air, changing the valve springs is easy.
    I think the best thing for you to do is:
    Install a set of 105s and new valve seals
    Install the modded rockers.
    Keep shift tables around 6k.
    If/when you decide to go cam:
    Choose cam and supporting mods (105's may be enough spring pressure)
    Swap modded rockers for stock rockers, sell modded rockers
    Install new cam and new timing chain/dampener, or roller chain setup.
    If you end up going with a larger cam and want to rev it higher 6500+ then I'd go ahead and put the 150's on, sell the 105's and go with a double roller.
  9. #9 Re: Valve springs
    Jan 2014
    East Grand Forks
    Awesome. That's exactly what I needed to know. Ya Ive done springs on my old regal because I had high shift points with the VS. Cam. Lol
  10. #10 Re: Valve springs
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Why is there no option of 130# spring? On my turbo application I went with 105's because never planned on running more than 10psi....and while I'm doing trans work here soon I'll be swapping in 130# springs. I wanted to stay away from having to do a double roller but looks like I'm going to end up doing one anyway.
    If you look at a lot of the turbo guys running big power the lowest spring they opt for is the 130....and quite a few run the 150s
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  11. #11 Re: Valve springs
    Jan 2014
    East Grand Forks
    I'm know springs are a great safety feature and needed. But thus yr Im planning on only 1.9 rockers. what are pros and cons for 90, 130,150 if say I stay under 6k shift or go more. I haven't had a real tube yet so Im. Not sure how much boost ill be able to push or how high Im gonna shift. All I k ow is pt61 with rockers on stock na motor. Lol
  12. #12 Re: Valve springs
    Florida
    Boost it til it blows!
    And GMR the only reason I didn't mention the 130's is because most people I've seen go turbo go for an all out setup, and not a more refined streetable route.
  13. #13 Re: Valve springs
    Apr 2011
    Columbus, OH
    I asked a very similar question and the general response is that rockers aren't ideal for turbo setups. Stick with stock cam and keep upping the boost and enjoy. Go cam right off the bat....if you're in the motor far enough to do valve spring and timing chain you're at the point where throwing in a cam would be just one more step.
    In general 90 are completely out of the option. It's been shown that the 105's are a better spring and after several people have shown that the 105s with stock timing chain is perfectly fine the popularity of 90's have really phased out.
  14. #14 Re: Valve springs
    Florida
    ^ Yep, the exact reason I went with 105'.
  1. LS6 90# Valve Springs - SOLD
    By tms8582 in forum For Sale - Parts
    Last Post: 11-19-2013, 03:02 PM
  2. Valve springs
    By 2000supercharged in forum General Grand Prix Discussion
    Last Post: 09-14-2012, 07:05 PM
  3. Valve Springs
    By stlmo_gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-13-2011, 07:21 PM
  4. valve springs
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2011, 07:32 PM
