Thread: Boost controller issue?
Results 1 to 7 of 7
  1. #1 Boost controller issue?
    May 2012
    Albuquerque, NM
    I'm curious, can a boost controller go "bad"? I ask because when I attempted to increase my boost I adjusted my boost controller (BC) a quarter of the way and it raised my boost about 2#s. I wanted to hit 10#s so I adjusted further, nothing, further, still nothing, further, nothing, all the way, still nothing. I adjusted in 25% increments and only noticed the first time it raised the boost at approximately 2#s. It is the BC that came with the Statama kit from ZZP. It was a used kit so I wonder, can I check the BC or can it be that my turbo is/can only make 7'ish #s? The car is not smoking as a usual blown turbo would. Also, I was told that the wastegate spring was a 9# spring but I have never once seen 9#s. I figured I just got bad information and the spring was actually a 5# spring, but now that I turned up the BC I'm curious as the PSI has not significantly increased. Thoughts, ideas, checks?
    Thanks,
    Slim
    2003 Chevy Inpala LS 3.8 l36, Stattama Turbo kit, P&P LIM, P&P heads, lS7 lifters, Intense Xtreme 7.05 oil restricted pushrods, ZZP 1.9 modded rockers, 3" no cat down pipe, poly mount all around, fuel rewire, alt volt booster, and still working on it...
  2. #2 Re: Boost controller issue?
    May 2012
    Where winter never ends
    What is your current boost level?
    Is the BC hooked up properly?
    If you run wastegate pressure do you actually hit full spool?
    Check for boost leaks in the piping, good ol' soapy water trick works great
    2000 Regal - Winter Beater
  3. #3 Re: Boost controller issue?
    May 2012
    Albuquerque, NM
    Yep, you were right. It was a screw up on my side. Next question, can it be mounted horizontally?
  4. #4 Re: Boost controller issue?
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Yep, you can mount the boost controller in any direction you'd like.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  5. #5 Re: Boost controller issue?
    May 2012
    Albuquerque, NM
    I have turned it half way so far and have not noticed a "significant" change. Any ideas? I is hooked up inline from my turbo outlet (nipple) to the bottom port of the Tial WG inlet. Hummm?
  6. #6 Re: Boost controller issue?
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    When I had I 5# spring I could only run 10# with the BC all the open and it took a few turns just to make a 2# increase. With it all the open how much do you hit?
  7. #7 Re: Boost controller issue?
    May 2012
    Albuquerque, NM
    Before BC and all the way open, I make right about 5. I will try it again but turned up I guess.
  1. Boost Controller
    By tazyboy28 in forum Off Topic Discussion
    Last Post: 12-21-2009, 07:55 PM
  2. Boost controller
    By selliott in forum Turbo
    Last Post: 10-19-2009, 05:07 PM
  3. Boost Controller
    By minichopper6hp in forum General Tech Discussion
    Last Post: 07-26-2009, 03:44 PM
  4. Boost Controller?
    By RicerKiller in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 07:23 PM
