Thread: Pushrods
Results 1 to 7 of 7
  1. #1 Pushrods
    Nov 2012
    Alright guys what would you recommend for pushrods I am running OER lifters with zzp stg4 heads and stock rockers also have a st5 cam.
  2. #2 Re: Pushrods
    Florida
    I would recommend that you get a pushrod length checker, and determine the proper lengths. Something like this
    http://shop.zzperformance.com/store/...cker-Tool.aspx
    And since you have such a beefy setup, I would recommend you go up to a 3/8s pushrod.
  3. #3 Re: Pushrods
    Nov 2012
    Yeh I was thinking probably the 7.050 ones would be a good selection
  4. #4 Re: Pushrods
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Get the length checker and go from there. Especially with the OER lifters that only want like .005" preload iirc. Head gasket thickness, whether the heads have been milled etc can affect pushrod length. Worth the time to set it up right. I ended up needing slightly shorter pushrods, got them from Manton (3/8") Reasonable cost and excellent quality.
  5. #5 Re: Pushrods
    Nov 2012
    Does it actually tell on the length checker the exact size your suppose to use?
  6. #6 Re: Pushrods
    Lorain, OH
    You will use it to get the proper preload, and then measure it with a caliper or similar instrument and that will be the length you need. Or better still, set it to 0 lash and measure (measure several or all valves) and then add your desired preload amount to the zero lash measurement. There is a writeup on the Zzp website iirc.
  7. #7 Re: Pushrods
    Nov 2012
    Alright thanks man I will probably have someone work with me on it too lol I have never messed with them.
  1. Intense Pushrods
    By tms8582 in forum For Sale - Parts
    Last Post: 11-27-2013, 11:38 AM
  2. Upgrade pushrods? Ye or Ne?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2013, 04:49 PM
  3. Lightweight Pushrods?
    By GMR Badass in forum General Tech Discussion
    Last Post: 02-20-2013, 06:04 PM
  4. pushrods
    By Stock4now in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-26-2011, 05:33 PM
