Thread: Why isn't my BOV "psssssshhhhh'ing"?
Results 1 to 7 of 7
  1. #1 Why isn't my BOV "psssssshhhhh'ing"?
    May 2012
    Albuquerque, NM
    So, I had the flange welded on, checked for leaks, none, mounted BOV, installed vacuum block, fixed leak, no more leaks, connected vac lines, drove, built boost, let off throttle, turbo sputter/surge, no pssssssshhhhhh.
    I don't understand. I thought all I had to do was install flange, install BOV, and install the vac line. Did I do something wrong?
    TIA,
    Slim
    2003 Chevy Inpala LS 3.8 l36, Stattama Turbo kit, P&P LIM, P&P heads, lS7 lifters, Intense Xtreme 7.05 oil restricted pushrods, ZZP 1.9 modded rockers, 3" no cat down pipe, poly mount all around, fuel rewire, alt volt booster, and still working on it...
  2. #2 Re: Why isn't my BOV "psssssshhhhh'ing"?
    Nov 2013
    Wisconsin!
    Where did you run your vacuum line from?
  3. #3 Re: Why isn't my BOV "psssssshhhhh'ing"?
    May 2012
    Albuquerque, NM
    The line originates from a nipple where the PCV used to be, goes into a vac block, one port then goes to top of BOV.
  4. #4 Re: Why isn't my BOV "psssssshhhhh'ing"?
    GT Level Member 1999black3800's Avatar
    Oct 2012
    Albany, NY
    Precision billet 6466 , 2-2500 RPMs
  5. #5 Re: Why isn't my BOV "psssssshhhhh'ing"?
    Nov 2013
    Wisconsin!
    I would try a different vacuum source to your block first. While a malfunctioning BOV is a possibility, its doubtful, what brand did you buy? A genuine, or Ebay knock off?
  6. #6 Re: Why isn't my BOV "psssssshhhhh'ing"?
    May 2012
    Albuquerque, NM
    It was this one:
    http://shop.zzperformance.com/store/...Off-Valve.aspx
    I turned up my boost control today and it started working. I don't understand why only an extra 2-3 pounds would make a difference but whatever. Thanks guys, maybe it just needed to be broke in.
    Slim
  7. #7 Re: Why isn't my BOV "psssssshhhhh'ing"?
    hangover park IL
    your bov spring may be too strong if it wont open at 2+ psi and the throttle closes
    its a balancing act...the spring must be strong enough to not open under all non boost vac conditions....it should only function when your making boost and that pressure effectively reduces the spring force that the valve "see's" and allows it to open...at 0-1psi you may not see it move. that is correct.
    if the thing functioned at 0psi then youd have the problem of when ever you let off the gas and decelerate the manifold vac spike will hold the bov open and cause a vacuum leak and allow the motor to suck in unfilter air through the bov.
    ~James~ Psychotic Gearhead
  1. """"""""""3inch Cutout""""
    By PWNED in forum For Sale - Parts
    Last Post: 12-10-2013, 08:10 PM
  2. 2006 Grand Prix "Reduced Engine Power" and "Service Traction System" warnings
    By chadwick in forum General Grand Prix Discussion
    Last Post: 10-04-2013, 09:59 PM
  3. Are there "Heavy load" or "helper" coils for the rear?
    By chrishova in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2013, 03:00 PM
  4. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  5. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
