Thread: Intake manifold
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Intake manifold
    Nov 2015
    Monroeville, Pa
    What im asking is if you can just put that intake on the lower intake from the L67. Did not see any info on that.
    97 cavalier with L67 swap. F23 Getrag trans with stage 3+ SPEC clutch, KB pistons, L32 rods, LS6 valve springs, 3.4 pulley, ZZP downpipe 2.5, Full rotating assembly balance.
  2. #22 Re: Intake manifold
    Kemmerer, Wyoming
    an F body intake manifold is completely different from an L67 manifold. you could put an F body L36 upper intake manifold on an L67, but there would be not bolt holes to line up.
  3. #23 Re: Intake manifold
    Nov 2015
    Monroeville, Pa
    Ok I see thanks. I like the idea of fabbing one up. They look really unique.
  4. #24 Re: Intake manifold
    Quote Originally Posted by nate halter View Post
    I'm sure you could.
    However if you looked at the way the runners are fed on both designs, it wouldn't make any logical sense.
  1. Intake Manifold
    By Speedy1973 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-02-2014, 09:00 PM
  2. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  3. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  4. intake manifold
    By eightballe in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2011, 01:30 PM
  5. Intake manifold
    By joesforspeed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2008, 12:15 PM
