Thread: Pics/advice on FMIC installation
Results 1 to 18 of 18
  1. #1 Pics/advice on FMIC installation
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Hi I have a pretty large FMIC that I got from CXRacing that it is time to install... I would like to know if anyone has pictures and/or ideas on how to brace/modify the hood latch support that is in the way of the intercooler as well as some pics of front bumper brace modifications. I would like to keep as much of the brace as possible as this is a DD car but also want to get as much air to the IC as I can. I Want to say it is a 13x36x3" core.. something in that area. If you have pics of how you mounted your IC and how you have the hood latch braced please either post here or send me a pm or email. Thanks!
  2. #2 Re: Pics/advice on FMIC installation
    Anthony Smith just did an install with a modded hood latch. GregBadass/Sven Sexman did one in Nov, Intrigue98 did one around xmas. there's a ton of pics etc for you to reference, enjoy.
  3. #3 Re: Pics/advice on FMIC installation
    Quincy, Mass
    we went to home depot and got some 1" steel flat bar that was i think 1/8" thick, maybe 5/16 we bent it using a vice so it was thick but not too thick. drilled some holes in it and mounted it underneath were splash shield mounts, used those holes, and i think we drilled some holes for it the top in front of the radiator. ill have to get some pics. the lower 2 required a couple of bends but it depends how low your ic sits.
    No more GP 04 Impala SS Indy:
  4. #4 Re: Pics/advice on FMIC installation
    Oh..and Swiggs did one!
  5. #5 Re: Pics/advice on FMIC installation
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Hope this helps. There is a list of piping I used.
    I did not have room to put the front support back on. I did make a custom chromoly support bar but have not installed it yet.
    Index of /members/silver2kgtp/A2A Intercooler
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  6. #6 Re: Pics/advice on FMIC installation
    Lorain, OH
    I must be a retard when it comes to forum searches because I can't find posts for those builds, especially interested in Anthony Smiths since he has the modded latch. can you clue me in on how to find those?
  7. #7 Re: Pics/advice on FMIC installation
    Apr 2011
    Vassar, Mi
    I see I'm a week late to this party but I don't peruse the turbo section much, it just makes me envious. In case you still haven't found it here's the hood latch I did for my 26x7x3 FMHE.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  8. #8 Re: Pics/advice on FMIC installation
    Quincy, Mass
    My hood latch has been cut since I was sc and ic. Hasn't been an issue.
  9. #9 Re: Pics/advice on FMIC installation
    Texas
    I have my build thread on here which has install pics of my IC. Click the link in my sig.
    85 Corvette
    01 TA
    03 Z06
  10. #10 Re: Pics/advice on FMIC installation
    Lorain, OH
    Quote Originally Posted by Swiggles View Post
    Did you ever take some pics of your hood latch setup? Just curious since that is my next task. modified the bumper bar a bit to try to get some more air to the IC without completely removing the bar. Will post some pics when I am done.
  11. #11 Re: Pics/advice on FMIC installation
    Quincy, Mass
    Mines been cut for a few years I never did anything to correct it. I do like Anthony's set up though. My top braces are bolted to the front bar that holds the front of the car together. Ill get some pics.
  12. #12 Re: Pics/advice on FMIC installation
    Feb 2008
    NY
    I didn't have to do anything to my hood latch and I have a big IC
  13. #13 Re: Pics/advice on FMIC installation
    Lorain, OH
    Quote Originally Posted by Silver2kgtp View Post
    But you don't have your front bumper bar anymore. My car is going to be a DD so I don't want to loose the crash safety of the front bumper bar. I cut out a section of it and re-welded a part of it.. hard to explain but I will take pics. But keeping the bumper bar in there is why you have to modify the hood latch support.I think I am going to notch it out like one guy did, just looking to see if there are any other creative and durable methods before I do.
  14. #14 Re: Pics/advice on FMIC installation
    Texas
    Quote Originally Posted by DJNight2k View Post
    I did its in my sig link. And I had to modify my hood latch due to the SD hood. I actually ended up welding part of an exhaust clamp to the bumper to get the hood to close.
    85 Corvette
    01 TA
    03 Z06
  15. #15 Re: Pics/advice on FMIC installation
    Feb 2008
    NY
    Ahhhhhh. Ok. I see now
  16. #16 Re: Pics/advice on FMIC installation
    Quincy, Mass
    We cut my bumper bar so the big one would fit in between the 2 pieces of it, so it's not much protection there but it helps hold the bumper up. My ic was only $150 on frozenboost.com so if I get in accident I'm not that worried. We cut the styrofoam too on the sides.
  17. #17 Re: Pics/advice on FMIC installation
    Quincy, Mass
  18. #18 Re: Pics/advice on FMIC installation
    GT Level Member ls1camino's Avatar
    Laurel, MD
    What are the dimensions on that, Swiggles?
    2000 Pontiac Trans Am WS6 M6: 427ci LS3, Built T56, Moser 9" w/ 4.11 Gearing, Full Suspension, and 6-point Cage.
    2000 Pontiac Grand Prix GTP: Twincharged (T67 Turbocharger).
    2007 Chevrolet Silverado 3500 Dually: Intake, Exhaust, and Tune.
  1. Replies: 26
    Last Post: 04-29-2012, 07:46 PM
  2. M90 3800 Supercharger Removal and Installation Video or Pics
    By Grand Prix1 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-19-2011, 03:43 AM
  3. Need HID installation
    By tc427 in forum Visual/Body Modifications
    Last Post: 07-02-2011, 10:08 PM
  4. NEED final advice before installation
    By jersey jok3r in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-10-2010, 12:11 PM
  5. HUD Installation- HELP???
    By lambokit in forum General Tech Discussion
    Last Post: 10-08-2009, 08:03 PM
