Thread: first turbo build questions
Page 7 of 7 FirstFirst ... 567
Results 121 to 123 of 123
  1. #121
    Quincy, Mass
    I'm running a ported stock l67 tb, the genV is the same bolt pattern as the l26 so just use an l67 to gen V plate. People seem to have a lot of trouble tuning with the n* and ls1 tb. Because the air is being forced into the intake by the turbo rather than the pulled in, you don't need a huge open throttle body.
    And before you ask, run a 99+ maf with a fixed afc.
    No more GP 04 Impala SS Indy:
  2. #122 Re: first turbo build questions
    GT Level Member DaytonaGTP500's Avatar
    May 2012
    Iowa
    lmao yea I've seen that alot, I would deff use my 2000 l67 throttle body and already have the fixed afc lol, but the main reason I guess for me asking is because zzp told me that I would have to machine the intake if i wanted run the l67 throttle body because the throttle body is so much bigger than the inlet on the intake, is this the truth or should I just ignore that lil piece? If you do have to machine the intake at all is it somthing I can get with my dremel and a couple hours?
    Quincy, Mass
    The genV adapter was the same size hole as the l26 uim intake hole. Don't know why they told you that.
    A flap wheel is better than using a dremel if did have to do it. But I didn't have to do anything.
  1. Turbo build. Run and tell that.
    By Wotgtp in forum Turbo
    Last Post: 05-25-2012, 04:08 PM
  2. Need help with my turbo build
    By Classy Pontiac in forum Turbo
    Last Post: 11-09-2011, 08:38 PM
  3. turbo build
    By Twist in forum Turbo
    Last Post: 10-13-2011, 12:30 PM
  4. Few turbo questions for the build!
    By 98GT3800 in forum Turbo
    Last Post: 08-13-2010, 08:42 PM
  5. Turbo build soon to come.
    By bbptech in forum Turbo
    Last Post: 03-05-2010, 09:37 AM
