Thread: misfires at idle
Results 1 to 10 of 10
  1. #1 misfires at idle
    Apr 2011
    Tally, FL
    Do you normally experience misfires at idle? is it a small count or some ridiculously high that goes away as soon as you get on the throttle?
  2. #2 Re: misfires at idle
    Omaha, NE
    No misfire is normal.
  3. #3 Re: misfires at idle
    What are you scanning with? Aeroforce is known to show you some.
  4. #4 Re: misfires at idle
    Apr 2011
    Tally, FL
    powrtuner and uvscan
  5. #5 Re: misfires at idle
    From what I've seen, modded 3800 seem to always have a miss at idle. Normally the count is really low.
  6. #6 Re: misfires at idle
    SE Level Member BlackGS's Avatar
    Central Jersey
    I have always misfired at idle since going turbo, and it is somewhat common. As long as the misfires are occurring on all cylinders and they go away under throttle, I wouldn't worry too much about it.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  7. #7 Re: misfires at idle
    May 2008
    Schuyler, NE
    ^^This
  8. #8 Re: misfires at idle
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Spark plug gap/plug wires can be the culprit, us turbo guys are always messing with plug gaps to keep spark blowout at bay, and that can sometimes lead to poor ignition at idle speeds for some reason. Try tweaking gaps or plug temps possibly and recheck all your plug wires to make sure they are in good condition and not arcing.
  9. #9 Re: misfires at idle
    Apr 2011
    Tally, FL
    Well mine occurs usually on 4 out of the 6 cylinders mostly on 3 and 6. Im using new acdelco stock wires are those to small? i notice when doing a cold start the misfire counts relatively low, but when i do a hot restart i get some crazy high counts that disappears once i get in gear. Wondering if a intercooler would help solve the problem?
  10. #10 Re: misfires at idle
    The size of the wire makes no difference, the cars electrical system can only do so many volts/amps. Upping the size as many do is strictly a "show" mod or because they want overpriced wires.
  1. Misfires?
    By Ultra440 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-27-2012, 03:45 PM
  2. car misfires
    By backinblackgtp in forum Engine
    Last Post: 03-24-2011, 03:25 PM
  3. Misfires in Cyl 4
    By mousemonster1232 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-09-2011, 02:38 PM
  4. misfires??
    By paulaxe in forum Engine
    Last Post: 11-23-2010, 04:09 PM
  5. WOT misfires
    Last Post: 11-12-2008, 08:58 PM
