Thread: ZZP "TAC" module
Results 1 to 4 of 4
  1. #1 ZZP "TAC" module
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Anyone with a turbo system use one of these? or can the same thing be achieved with tuning? Site says they are recommended for blow through (ie turbo) systems. Esp. those with maf scaled more than 85% to correct engine load calculations.
    Easy Performance - TAC #EP-TAC
    Just curious if its a good investment or a gimmick or for someone that for some reason isn't tuning.
  2. #2 Re: ZZP "TAC" module
    Quincy, Mass
    I had the tac when supercharged but I never noticed much difference. And I'm pretty sure you can just tune the PCM to do what the tac would do. Are you running a stock/ported tb or a n*/ls1?
    No more GP 04 Impala SS Indy:
  3. #3 Re: ZZP "TAC" module
    Lorain, OH
    Stock 99+ tb/maf turbo
  4. #4 Re: ZZP "TAC" module
    Quincy, Mass
    Hmm I don't think I ever read the additional info on that until now. If your having trans/converter issues it might be worth a shot to try.
  1. lost "D" and "3" the car only move forward in 2nd
    By asite57 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2012, 11:17 AM
  2. "Stage 2" ZZP axles: A..."mild"...quality issue.
    By RareGMFan in forum Off Topic Discussion
    Last Post: 07-31-2011, 05:35 PM
  3. Chug at start, "bouncing" tach when key turned to "on"...
    By KZOO3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-21-2011, 10:50 PM
