Thread: fuel rail?
Results 1 to 7 of 7
  1. #1 fuel rail?
    GT Level Member deadsnake's Avatar
    Round lake, IL
    What fuel rail would you recommend I use with a l26 uim? Thanks!
    '04 MC Intimidator SS,'96 Camaro Z28 ,'98 GTP 12.9 trap
    '93 383 stroked Trans am (Crashed),
    '93 Chevy c1500 Pickup Indy500 Special edition,
    '01 VW GTI Garrett 50 trim, '98 GTX clone (Current car) Working on Top swap!
  2. #2 Re: fuel rail?
    Nap
    I have the PRJ rails and love them.
    T4/T67 turbo, PRJ tune, 9.5:1 forged pistons & race block, Oversize air/air IC, 3 inch exh, Electric W/P, 1.6 RR, 3.29 gears, 3750 stall, Intense STAGE 4 TURBO CAM AND HEADS, 65# Inj, GEN 3 LSD, 255 f/p, 103's, white w/ blue pearl, Ghost flames, B&G spg. + more.
  3. #3 Re: fuel rail?
    Jan 2012
    Philadelphia
    if your going for looks get PRJ rails or ZZP billet rails maybe even ZZP modded rails. if you just want to make it work im thinking L36 rails not sure if the L67 rails will fit i know L26 and L32 rails will not work on a 97-03
    Ohio
    Use l36
  5. #5 Re: fuel rail?
    Feb 2009
    flintnasty MI
    I like the L26 rail with a hacked up regulator mounted on the firewall.
  6. #6 Re: fuel rail?
    Texas
    I use ZZP modded rails and they were a ***** to get seated with a L36 UIM. You could always hack up your L26 rails use fuel hose.
    If I had to do t all over again and I had the cash I'd throw down the coin and get some PRJ rails.
    85 Corvette
    01 TA
    03 Z06
    Quincy, Mass
    Which heads are you using? I'm pretty sure the l36 rails will fit over the l26 intake.
    No more GP 04 Impala SS Indy:
  1. fuel rail ???
    By green18gtp in forum General Tech Discussion
    Last Post: 01-26-2012, 08:41 PM
  2. fuel rail
    By YoungGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2008, 01:09 PM
