Thread: Oil volume kit. anyone using one?
Results 1 to 16 of 16
  1. #1 Oil volume kit. anyone using one?
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Working on assembling my turbo build. anyone running the intense (or other) oil volume kit? or is everyone pretty much just running the stock oil pump setup etc. ? Curious if the volume kit would be useful for the additional oiling the turbo uses or would that end up pumping too MUCH oil into the turbo, (I know some ppl run restrictors on the oil feel line to the turbo) Thanks for any input you have.
    Ohio
    It's not necessary
  3. #3 Re: Oil volume kit. anyone using one?
    Oil volume kit is an 04+ accumulator spring and valve.
    Its cheaper at the dealer than it is via ZZP.
    Our vehicles will produce 60 PSI at any level of throttle.
  4. #4 Re: Oil volume kit. anyone using one?
    Lorain, OH
    is it worth getting (i work at a dealer so it'd be pretty cheap) or just run stock one? And a side note, what oil are you guys running (turbo DD cars)
  5. #5 Re: Oil volume kit. anyone using one?
    most people like to run diesel oils.
    5w40 synthetic and the like.
    I'd get it if you work at the dealer.
  6. #6 Re: Oil volume kit. anyone using one?
    Quincy, Mass
    the oil psi is not needed with the turbo kits
    No more GP 04 Impala SS Indy:
    Then why run 40 weight oil?
  8. #8 Re: Oil volume kit. anyone using one?
    Lorain, OH
    yes why do we run such heavy weight oil in our turbo cars? i've gotta ask matt, maybe he can give some technical insight on why.. or if its just a myth that we all follow And it figures there would be a debate on whether or not to use the volume kit.. nothing is ever a cut and dry yes do it or no it will make things worse kinda thing lol. Thanks for the input!
  9. #9 Re: Oil volume kit. anyone using one?
    Quincy, Mass
    i use 10w30 should be using something different?
  10. #10 Re: Oil volume kit. anyone using one?
    Lorain, OH
    Well a lot of ppl I've talked to run diesel 15w40 or 5 or 10w50 but always wondered if it was really necessary or just someone's suggestion that others copied and became popular. Or is there any real proof that they are beneficial and worth the amount of power n economy the heavier oils rob.
  11. #11 Re: Oil volume kit. anyone using one?
    Only conjecture.
  12. #12 Re: Oil volume kit. anyone using one?
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    I use Shell Rotella T6 synthetic and run the 5w40 formula, I can catch it on sale and get it much cheaper than the 10w30 Mobil I previously ran and the car is only driven in spring/summer/fall anymore. The 40w stands up a little better to the heat the oil sees in the turbo and doesn't darken as quickly. The Rotella is also formulated for heavy duty use and non coking for turbo applications.
    Been using it two years now and pretty happy with it overall.
  13. #13 Re: Oil volume kit. anyone using one?
    Lorain, OH
    My parts guys say the 04 spring and valve are the same for 98-08.. interesting. Wonder if they updated the old ones with the different part or if there is really no difference...
    Can he not check to see what numbers it superceded if any?
  15. #15 Re: Oil volume kit. anyone using one?
    Lorain, OH
    they both do not show any old part numbers associated with the current part numbers. The spring is good from 1978-2009 and the valve is good from 1985-09 so I don't know. I am not sure if they always show old numbers though on all parts or not. I know some do. I will try to dig a little deeper when he has more time. I work with him, so I don't want to irritate him too much with this stuff all at once.
    Its cool.
  1. oil volume kit.from zzp?
    By TEK310 in forum General Tech Discussion
    Last Post: 03-13-2012, 05:41 PM
  2. fix for radio volume
    By 59chevy in forum Audio, Security & Visual Electronics
    Last Post: 02-15-2011, 05:13 PM
  3. Sub box volume question
    By josemolina2008 in forum Audio, Security & Visual Electronics
    Last Post: 08-24-2010, 02:09 AM
  4. One Volume only
    By emmi in forum Audio, Security & Visual Electronics
    Last Post: 04-15-2010, 09:21 AM
  5. Sub Craps Out When Volume Goes Up
    By hondo in forum Audio, Security & Visual Electronics
    Last Post: 02-08-2010, 10:56 PM
