I love the valve covers the paint job is awesome. I see you have the front one on the back is there a reason for it?
So you have a smooth front VC, no oil cap in the way.
your going to need to vent that front valve cover somehow. too much pressure in the crank area = bad. and i was told by stattama not to wrap the cross over since it can crack if your do. looking good otherwise.
I would tap a fitting in the front cover and run a tube to a catch can, then the other tube can just go wherever.
Haven't decided on a catch can or anything yet. Car should be up and running this weekend
Got lots more work done today, second crank and guess what! it started with no problems, had a few exhaust leaks, will fix tomorrow and continue with the tune. After that I will focus on cosmetic issues.
