Ok I know gtp runs like 7-8 psi of boost from the sc. I was wanting to know if I would be able to switch over to a turbo setup and run around the same amount of boost. I know sc vs turbo boost is different. Maybe alittle less boost from the turbo. I know turbos are more efficient. What would I need fuel,spark,and tuning wise?
With that low of boost I wasn't going to worry about a intercooler
All info is wanted and needed thanks
