Thread: A/A fmhe air dam won't fit. How to get car to cool better?
Results 1 to 11 of 11
  1. #1 A/A fmhe air dam won't fit. How to get car to cool better?
    Aug 2011
    Millbury, OH
    I purchased my car with a Stattma turbo setup but all of the parts were off of the car. When I put everything back for the intercooler setup I noticed the the air dam and other plastic pieces around the radiator no long would fit due to the size of the FMHE.
    i was wondering if anyone has come up with anything to help get more air flow across the radiator so that it cools better?
    thanks
    2000 GTP coupe, Stattama Turbo Setup, A/A intercooled, custom cam, Tischler heads, 3250 stall, Zzp trans, 1" GMR chain, 65# injectors MDP hood, MSP exhaust, and much more.
  2. #2 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    GT Level Member t24moore's Avatar
    Feb 2008
    Houston
    Nope, dont think there is a way because most FMICs hang too low. Most people dont have issues with cooling tho.... I dont atleast.
    Comp Turbo 6765 T4-ST5-A2A IC-Ported Heads-Custom Turbo headers-80 lb inj-F-Body UIM and LIM-AEM WB, TEP trans w 1" chain and Circle D TC, Dual 255s, Bilstien Struts
    WHY IS EVERYONE SO OPPOSED TO DOING A COMPRESSION TEST TO TROUBLESHOOT PROBLEMS?
  3. #3 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    Aug 2011
    Millbury, OH
    The car isn't overheating. It's just getting around 200 with a 160 stat while on the highway. I have an electric water pump and I was wondering if that might be the problem too.
  4. #4 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    Hate to break it to you buddy but it doesnt matter what temp tstat you put in there cruising down the highway your going to run about 190-200, the 160* tstat only controls when the fluid starts flowing around inside the engine it doesnt make it run cooler. Once the engine warms up it warms up. Only thing to get it to run cooler would be a much larger radiator.
  5. #5 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    Feb 2008
    Houston
    And off topic
    Originally Posted by The Sunfire Guy
    They do....
    It take power to spin the blower thus in effect taking away HP.
  6. #6 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    Jan 1970
    Maquoketa, Iowa
    Do you have it tuned so the fans will even come on at 160?
  7. #7 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    Aug 2011
    Millbury, OH
    Yes the fans come on at 160. But going down the highway fans don't make a whole lot of difference.
    I also have an electric water pump. I was thinking I might try a different pump as well.
  8. #8 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    Texas
    I'm rigt there with you on this one. My temps get fairly hot driving in the summer.
    85 Corvette
    01 TA
    03 Z06
  9. #9 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    Aug 2011
    Millbury, OH
    Ended up being the Electric water pump that I had. Replaced it with a stock one and the temps went down. So I'm having the electric pump rebuilt.
  10. #10 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    Texas
    Quote Originally Posted by TheGerm View Post
    Good deal. Thanks for the update. I'll be doing my water pump as well. 200K on the engine and I don't believe the pump was ever replaced. Have a feeling that the blades are missing.
    85 Corvette
    01 TA
    03 Z06
  11. #11 Re: A/A fmhe air dam won't fit. How to get car to cool better?
    Grand Island, Nebraska
    You probably solved this problem already but theres a thread on here somewhere about a monte carlo radiator being bigger.
  1. best fmhe
    By qball98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-29-2009, 04:30 AM
