Thread: AFC or different MAF?
Results 1 to 5 of 5
  1. #1 AFC or different MAF?
    Nov 2012
    utah
    ok guys i need some help with my MAF. what do i need to do so i dont have to run a AFC? or is it even possible? i know the stocker runs out at 11500 hz some have said the lt1 maf has more head room. but istn it the pcm that is maxed out at recieving the 11500 hz? I am wanting to turn up my boost but want to get this all situated first
    thanks
  2. #2 Re: AFC or different MAF?
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    You will need to be able to tune if your going to change your maf. I run the lt1 and have pushed 15 pounds without a problem. How much boost are you wanting to go up to?
  3. #3 Re: AFC or different MAF?
    Nov 2012
    utah
    I would like to get around 15. Do I just need to change the maf tables for that maf? And then get a tune on top of that.
  4. #4 Re: AFC or different MAF?
    Anytime you upgrade the throttle body or MAF, a custom tune is needed so that the PCM knows what its working with.
  5. #5 Re: AFC or different MAF?
    Nov 2012
    utah
    Ok I can handle that. I have someone who can put in the tables. I'll just get a lt1 maf unless there is something better
afc, maf
