Thread: Anyone run with out a MAP sensor?
Results 1 to 8 of 8
  1. #1 Anyone run with out a MAP sensor?
    Texas
    Just curious as I have been having issues with my car since I got rid of the M90 block off and moved to a ported LIM, L36 UIM, and ported TB. The car starts to build boost, but for some reason hits a wall at 4500ish RPM's. If I give it a some gas build some boost then let off the car dies. If I drive the car normally and ease up to speed it drives fine and doesn't die.
    Video for reference:
    Boost cutoff? - YouTube
    I have a intercooled CT kit with LT1 MAF
    85 Corvette
    01 TA
    03 Z06
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    I'm running my L26 turbo with no map sensor and didn't have any problems except for a code. Couldn't you try and put a tee in off the vacuum line and run a hose off the tee to the map sensor?
  3. #3 Re: Anyone run with out a MAP sensor?
    Jan 1970
    Maquoketa, Iowa
    What kind of vacuum lines are you using or have you changed to?
  4. #4 Re: Anyone run with out a MAP sensor?
    Wasn't it an L67 to begin with?
    And you added an L36 LIM?
    What did you do about the injector bosses?
  5. #5 Re: Anyone run with out a MAP sensor?
    Donating Users Tengis's Avatar
    Houston
    Soo... are you running a MAP sensor? 1 bar or 2 bar?
    Either run an L36 bin file with a 1 bar MAP sensor or run an L67 bin file with a 2 bar map sensor.
    You can use a 2bar MAP sensor from a 2004+ GTP on the L36 UIM.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  6. #6 Re: Anyone run with out a MAP sensor?
    Texas
    Quote Originally Posted by FoSHO99 View Post
    Mix of silicon and rubber
    Quote Originally Posted by Wsmccoy View Post
    tried going directly to UIM and to vac block with same results.
    Yes was L67 and replaced the M90 case with a ported L26 LIM. Injector bosses tig welded closed and vac gauge is reading -18 at idle.
    Quote Originally Posted by Tengis View Post
    Running L67 MAP
    I also have an enhanced AFC that I might start playing with.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: Anyone run with out a MAP sensor?
    Southfield,MI
    Also r u running a gt PCM file or a gtp PCM file. Cuz of u don't have a gtp operating systems "osid" the map sensor will not read boost
  8. #8 Re: Anyone run with out a MAP sensor?
    Texas
    Quote Originally Posted by alsaiyadal View Post
    L67 PCM shelf "tuned" for a turbo.
    85 Corvette
    01 TA
    03 Z06
  1. thermostat temp sensor and interior air temp sensor failure?
    By lewethetiger73 in forum General Tech Discussion
    Last Post: 11-26-2011, 10:07 PM
  2. question about low coolant sensor,fuel level sensor,and the
    By spider4 in forum General Tech Discussion
    Last Post: 11-26-2011, 09:19 AM
  3. camshaft sensor or crank sensor?
    By Viper in forum 3.1L V6 (LHO/LG8)
    Last Post: 09-06-2010, 04:43 PM
  4. Picture request of Coolant Temp Sensor and TPS sensor parts
    By David A Smith in forum Shops and Community Heroes
    Last Post: 06-11-2010, 11:05 AM
