Thread: Not building full boost
Results 1 to 6 of 6
Wsmccoy Not building full boost 05-19-2012, 06:08 PM
MoarkatsINmuhtrailer Picture of how your lines are... 05-19-2012, 09:10 PM
Wsmccoy Ya it's an atmospheric dump.... 05-19-2012, 10:00 PM
darkhorizon Re: Not building full boost 05-20-2012, 11:45 PM
bigburban Re: Not building full boost 05-21-2012, 06:19 AM
Wsmccoy So I was finally able to get... 05-21-2012, 06:43 AM
  1. #1 Not building full boost
    SE Level Member Wsmccoy's Avatar
    May 2012
    Fort Campbell, ky
    So I have a 2007 gp with a Z3 turbo kit and I have a boost controller. I'm only able to get 5 pounds of boost, even if I turn up the manual boost controller. I have checked for vacuum leaks and didn't find any. Could it be the bov or wastegate? Oh and it's a tial wastegate and Stattama bov
    Ohio
    Picture of how your lines are routed?
    Are you running an atmospheric dump?
    May 2012
    Fort Campbell, ky
    Ya it's an atmospheric dump. I have a tee where the map sensor was and off the tee it runs to my bov and the other side of the tee to the lower port on my wg. On the hose that runs to the wg I put a tee in and ran it to the boost controller and then off the boost controller to the upper port on the wg.
    Sorry for the crappy phone pictures it's all I have right now
  4. #4 Re: Not building full boost
    Feb 2009
    flintnasty MI
    its setup legit. Take the boost controller off and see how well you can blow through it. The more pressure you put on top of the waste gate the more boost you make.
  5. #5 Re: Not building full boost
    Apr 2012
    nova
    boost leak?
    1999 gtp coupe... P&P heads, lim, and sc, comp vs cam, intake, dp and ubend
    2003 ford ranger fx4 level II- twin stick
    May 2012
    Fort Campbell, ky
    So I was finally able to get the boost controller to work and got it up to 10 pounds. I drive the car for half a day came home washed the car and went to go drive it and now I'm only getting 3 pounds of boost. The bov doesn't sound the same as before so I'm thinking it has to either be the bov or wastegate leaking or possible exhaust leak. I'm still starting to spool boost at the same rpm but it just won't go above 3 pounds.
  1. not building boost anymore?
    By fst in forum Turbo
    Last Post: 03-04-2011, 08:12 PM
  2. I have full boost now.
    By Lsick7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 10:52 AM
  3. FWI installed!! ...still not getting full boost though...
    By 03GTPLE in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2009, 04:20 PM
  4. not getting full boost?
    By Standby in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2009, 05:43 PM
  5. Building Boost much faster
    By JCG's-GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-31-2009, 02:12 AM
