Thread: Turbo L36 vs. Turbo L67
Results 1 to 10 of 10
  1. #1 Turbo L36 vs. Turbo L67
    Jersey
    So i was thinkning about saving for a turbo/built trans combo build. I defintily want to swap the motor before i turbo my car for a motor a little less used up. Im curious to know the advantages and disadvantages of an L36 motor vs. L67 motor. I cant decide on whats a reliable/safer setup.
    16' wrx sti- stock
  2. #2 Re: Turbo L36 vs. Turbo L67
    Jan 1970
    Maquoketa, Iowa
    L36 has higher compression, you would make more power under less boost. The upper intake manifold on the L36 is also a good turbo manifold, its glass reinforced and you don't have to buy the block off plate for the supercharger. L36's can be found a little cheaper than the L67's. The L32 or L26 engines are better than the L36/L67 though.
    I'd go with a L26 and a Z7 kit with front/rear powerlogs and a DIY large A/A intercooler along with a built trans with the 1" chain. Should run you around $6000+.
  3. #3 Re: Turbo L36 vs. Turbo L67
    an l67 will take more boost in the long run. youll find out that all the big turbo guys have an l67 block.
    the higher compression will just make the car feel like it runs better during normal cruising.
  4. #4 Re: Turbo L36 vs. Turbo L67
    GXP Level Member offroadfury6's Avatar
    Aug 2008
    Fayetteville, NC
    because of this....this thread doesnt even mention my motor
    2011 Honda Civic EX-L - Leather/Sunroof/LOADED!
    2009 Saturn Aura XE - I got shift paddles!!!
    '98 Olds Cutlass - Good, Dependable
    '06 GP GT S/C - Traded it in
  5. #5 Re: Turbo L36 vs. Turbo L67
    Barksdale AFB, LA
    The L32 has the strongest bottom end of any 3800. They're just expensive to get a hold of if you don't already have one. That's why it wasn't mentioned.
    2009 Subaru Impreza WRX STI
  6. #6 Re: Turbo L36 vs. Turbo L67
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    L67 here
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  7. #7 Re: Turbo L36 vs. Turbo L67
    Aug 2008
    Fayetteville, NC
    how can you tell which one you have?
  8. #8 Re: Turbo L36 vs. Turbo L67
    Barksdale AFB, LA
    Quote Originally Posted by offroadfury6 View Post
    Series II N/A = L36
    Series II SC = L67
    Series III N/A = L26
    Series III SC = L32
  9. #9 Re: Turbo L36 vs. Turbo L67
    Aug 2008
    Fayetteville, NC
    o dang i guess i have L32, thats bad huh?
  10. #10 Re: Turbo L36 vs. Turbo L67
    Barksdale AFB, LA
    Why would it be?
  1. anyone know why my turbo does this???
    By lilredss0287 in forum Turbo
    Last Post: 08-23-2008, 09:11 AM
  2. Turbo Gxp!!!
    By PshnLck18 in forum Turbo
    Last Post: 08-18-2008, 12:23 AM
  3. Turbo Question
    By BKA05GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-19-2008, 08:41 PM
  4. ZZP power log on a turbo car?
    By Smokedgtp in forum Turbo
    Last Post: 05-07-2008, 06:07 PM
  5. Turbo Kits
    By robahr24 in forum Turbo
    Last Post: 01-24-2008, 09:25 AM
