Thread: 9 psi with an NA
Results 1 to 19 of 19
  1. #1 9 psi with an NA
    GTP Level Member
    Sep 2011
    Motown
    Would i beable to run a turbo with 9 psi on a l26 with msd ignition, custom powerlogs, 65# injectors, and a CAI?
    Quote Originally Posted by deadwoodspecial View Post
    On a side note, I do want to add that Classy is keeping it classy through all of this. The guy has a hell of a business ethic, and is doing everything possible to make this right. If anyone was, is, or has considered getting retro's, I HIGHLY recommend him. Good prices, and he backs his sh!t.
  2. #2 Re: 9 psi with an NA
    Out West
    If tuned properly. Probably.
    Whine with your Cheese?
  3. #3 Re: 9 psi with an NA
    Omaha, NE
    9PSI isn't a lot. I was running 11 on my L26 with a topswap.
    I only have 42.5# injectors, I don't know why you couldn't get away with the same.
    You'll probably want to replace the timing chain and put a higher pound spring in the heads.
    Last but not least, ditch the MSD coils for stock, they are notorious for having issues.
  4. #4 Re: 9 psi with an NA
    GTP Level Member AjL227's Avatar
    IL
    If you're going with 65# injectors or larger, you may as well run E85 thus giving you more headroom with boost at that compression ratio.
    Now the transmission is a different story.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  5. #5 Re: 9 psi with an NA
    Jan 1970
    Maquoketa, Iowa
    9 psi if tuned right, looking at high 12's. May want an intercooler, get a decent core and then piping from ebay to keep it around $300-400 total for an a/a.
    M90 boost #'s are irrelevant to turbo boost #'s, many things that change.
  6. #6 Re: 9 psi with an NA
    Feb 2009
    flintnasty MI
    I ran over 17psi on e85 through a stock L26.
  7. #7 Re: 9 psi with an NA
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    My L26 was running 15psi with any issues..... before trans failure.
    Retired
    Turbo'd
  8. #8 Re: 9 psi with an NA
    GTP Level Member
    Sep 2011
    Motown
    Hey victor, i was looking at your cardomain site of the Prix and noticed you had a custom tune. Did you get a custom dyno tune or did you get a canned tune?
  9. #9 Re: 9 psi with an NA
    GTP Level Member
    Sep 2011
    Motown
    Why are the msd coils bad?
  10. #10 Re: 9 psi with an NA
    Jun 2011
    Detroit, MI
    They fail more than stock ones, can cause misfires.
    iLoveSpade
  11. #11 Re: 9 psi with an NA
    Omaha, NE
    Stock coils have more power output than MSD's. Proven. You want your car to run better? Get Autolite 606 spark plugs and get better WIRES, like MSD's or PRJ's. Stock coils are used on most of the fastest WBodys around...why? Because they are proven to not fail...just go grab a new set from Autozone OR... Morad Parts Company - 3800 Motors, Transaxles, & Stock Parts
    source: http://www.grandprixforums.net/msd-c...ice-40299.html
  12. #12 Re: 9 psi with an NA
    Dec 2008
    Tyrone, PA
    Quote Originally Posted by Classy Pontiac View Post
    I started with the canned tune from ZZP that comes with the turbo kits. That got me to 115 traps and 15psi with no knock. Afterwords a friend of mine worked on the tune to straighten a few things out, like leaning the car out some for more power.
    Retired
    Turbo'd
  13. #13 Re: 9 psi with an NA
    im not so sure i understand why this thread is based around a certain level of boost. if you run a turbo, you should have a boost controller. therefore you run whatever you can before it knocks, unless im just completely retarded and you base a motor build around running a certain boost level (which would be stupid as hell).
  14. #14 Re: 9 psi with an NA
    GTP Level Member
    Sep 2011
    Motown
    Bio, i will have a boost controller but right now the wastegate i have has a minimum psi of 9 psi because the spring in the wastegate is a 9 pound spring. I just wanted to know if a stock l26 could even handle 9 psi.
    Thanks victor for the reply. Thats all i needed to know about the tuning part.
  15. #15 Re: 9 psi with an NA
    GT Level Member kuntzie's Avatar
    Feb 2010
    Kitchener, Ontario, Canada
    I've ran 30+psi on an n/a block
    02 Grand Prix GT Intercooled turbo 5-speed 718whp 618wtq @ 21psi 7575 billet, spool valve, custom manifolds, 4" downpipe, 16way adjustable coilovers, 18x9.5 with 275's all around, gxp interior, gxp brakes
    tilton triple disc, custom aluminum flywheel, tilton slave and master, an awful lot more
  16. #16 Re: 9 psi with an NA
    Quote Originally Posted by kuntzie View Post
    L36 maybe...but L26's poop their rods out like clockwork on higher HP builds.
  17. #17 Re: 9 psi with an NA
    Feb 2009
    flintnasty MI
    You would have some major trouble handling "30psi" on a NA car with anything...
    Most any of my SC blocks can realistically make power at is about 22psi with a decent cam. Anything more than 20psi on a NA block without a decent cam is overkill.... anything over 25psi with a decent set of heads/cam is 900hp.
  18. #18 Re: 9 psi with an NA
    Jan 1970
    Maquoketa, Iowa
    Fuel (octane), tune and the temperature of the air coming through the throttle body play the largest part.
  19. #19 Re: 9 psi with an NA
    GTP Level Member
    Sep 2011
    Motown
    Thanks for all the help, it was greatly appreciated.
