Thread: turbo cam vs rockers ???
Results 1 to 20 of 30
  1. #1 turbo cam vs rockers ???
    GT Level Member grandprix5's Avatar
    brownsville
    ok so i have a 2005 grand prix turbo spec/ turbonetics 60-1 turbo , 42.5 injectors, intercooled, my goal its just hit the 12's i dont want anything else as long its a 12.99 that works for me. what would work better a cam or rockers ?? and what rockers are better and what ca is better ?? and also need info about the prices ? if i go with the rockers il be putting rockers and the HV3 and if i put a cam i just going with a cam ! what do you guys think works better fr me ?
  2. #2 Re: turbo cam vs rockers ???
    Cam it, hands down a better mod. You will be able to use your powerband better.
  3. #3 Re: turbo cam vs rockers ???
    If your not in the 12's in an intercooled, turbo kit...your doing it wrong.
  4. #4 Re: turbo cam vs rockers ???
    12.9 LOL should be pretty easy rockered, turbo non IC'd with some decent tires!
  5. #5 Re: turbo cam vs rockers ???
    MO
    my thoughts exactly
    <brandonl2000> LMAO D!!
  6. #6 Re: turbo cam vs rockers ???
    Texas
    You are still going to need valve springs if opting for a cam. If you get the ST1 from ZZP it requires at minimum 90lb springs. And if you have over 75K it's recommended to get a new timing chain with a cam swap. If going with the ST3, ST4, or ST5 then its recommend to use 130lb springs. Which means you are going to need/want a double roller timing chain. And if you get that you are going to need a machined cover. Then a tune for those as well. So thus the money pit ensues.
    If you are just looking for high 12's then 1.9 rockers will get the job done.
    85 Corvette
    01 TA
    03 Z06
  7. #7 Re: turbo cam vs rockers ???
    brownsville
    yeah i dont want anything big i just want to hit the 12,s i think im just going with the rockers it seems lets trouble and less money for my goal... everything was going really good til yesterday my turbonetics turbo started to sound wird i pulled out the turbo and found out that the turbine wheel its really damage thats whay i had a problem creating boost fast so i just send an email to importevolution the guys who sold it to me and said it has warranty and their going to rebuild it !
  8. #8 Re: turbo cam vs rockers ???
    brownsville
    98grandprixiraqvet do you still have your s256 ???
  9. #9 Re: turbo cam vs rockers ???
    Quote Originally Posted by grandprix5 View Post
    Why of course I do lol! Im a broke ass college student now. Still 700 dollars shipped if you want it. Everythings forsale but not up for lowballing!
  10. #10 Re: turbo cam vs rockers ???
    Quote Originally Posted by 98GrandPrixIraqVet View Post
    Told you that you wouldn't build it.
  11. #11 Re: turbo cam vs rockers ???
    Feb 2009
    flintnasty MI
    Honestly, I have always seen the most power gains in turbo cars from JUST upgrading the springs.
    If you do rockers, or a cam, expect to do a large spring upgrade... I would probalby just suggest to you to keep stock rockers, and put on some yellow/blue LS6 springs. The rockers would be a decent upgrade, but I can still run 17-18psi of boost on stock rockers as easily as I could with 1.9 modded rockers. The springs really helped out things no matter what rockers i had on.
  12. #12 Re: turbo cam vs rockers ???
    brownsville
    darkhorizon thats a lot of help you thing guy i can run a high 12's with just my turbo intercooled? without adding rockers or cam ??
  13. #13 Re: turbo cam vs rockers ???
    Feb 2009
    flintnasty MI
    I ran 11.2 in my fiero on stock springs.... 11.5 on 93 octane on a conservitive tune... The tanker truck wbodies do struggle to run as fast as my fiero does... but 12s should be plenty easy.
  14. #14 Re: turbo cam vs rockers ???
    Youtube some turbo grand prix's...I'm trying to tell you...12's are a cakewalk.
  15. #15 Re: turbo cam vs rockers ???
    brownsville
    cool so i think im just going to stay with out rocker and with out cam and just upgrade the springs like horizon said and im going to take her to the track next month and see if i hit the 12' that i wanted
  16. #16 Re: turbo cam vs rockers ???
    brownsville
    and i guess this is the part number for the springs GM 12499224 right horizon ??
  17. #17 Re: turbo cam vs rockers ???
    brownsville
    what turbo do you have in your fiero ?
  18. #18 Re: turbo cam vs rockers ???
    Feb 2009
    flintnasty MI
    I had a HX35 holset, which is similar to the 60-1 turbo found on many turbo kits.
  19. #19 Re: turbo cam vs rockers ???
    Texas
    Don't expect to run the same time as him though. A Fiero has a rear mount engine, "RWD", and is much lighter than a GP. Comparing a fiero(with a 3800) to a GP is like comparing apples to oranges.
    85 Corvette
    01 TA
    03 Z06
  20. #20 Re: turbo cam vs rockers ???
    Feb 2009
    flintnasty MI
    Quote Originally Posted by txslow6 View Post
    I wouldnt go so fast there... Mod for mod fieros struggle to run much more than a second faster than wbodies... I dont see any reason why the average wbody with a turbo kit bolted on cant run than 12.2-12.4 if my fiero is running 11.2-11.4.
