Thread: 18" rims with Turbo
Results 1 to 13 of 13
  1. #1 18" rims with Turbo
    SE Level Member Amb4's Avatar
    Nov 2009
    Canada
    Someone told me that 18 inch rims with a turbo can cause CV shafts to break more often and that i should run 16's with it.
    Is this true because i like the look of my 18's way better and im in the market to be putting some new rubber on either rims so i want to know which one i should be shopping for. Thanks for any input
  2. #2 Re: 18" rims with Turbo
    snapping CV shafts would probably be related to launches.
    if the 18's weigh more than a stocker combo (which is the case most of the time) it will put more strain on everything in the drivetrain.
  3. #3 Re: 18" rims with Turbo
    I live here. TLSheff's Avatar
    Given that GXPs run 18s factory, I don't think its so much the wheels, but the turbo (mainly launches)
  4. #4 Re: 18" rims with Turbo
    North Jersey
    Or just invest in lightweight wheels
  5. #5 Re: 18" rims with Turbo
    GT Level Member VictorSmalls's Avatar
    Dec 2008
    Tyrone, PA
    18's here.
    I think snapped axes can be a way of life in a turbo car depending on how you drive.
    Retired
    Turbo'd
  6. #6 Re: 18" rims with Turbo
    Jul 2008
    sumter,south carolina
    i snapped a axle when i was bone stock on a launch... sh1t happens.. i think gm still sells their race axles.. if not im sure zzp has some beefy ones.
    edit.. http://www.zzperformance.com/grand_p...cts.php?id=105
    02 GTP with mods 05 GP for DD
  7. #7 Re: 18" rims with Turbo
    Nov 2009
    Canada
    Alright perfect. I already have the upgraded half shafts in the car so hopefully they hold up! Ill just put the rubber on the 18's and not launch it like an ass
  8. #8 Re: 18" rims with Turbo
    Donating Users Tengis's Avatar
    Houston
    The upgraded axles are known to be weaker then stock. Im 99% sure ZZP uses stock GM axles on their race cars.
    Heavier wheels would put more strain on the axles. Lower the car and changing the geometry can apparently cause issues as well.
    Silver R32 Skyline GTS-T
    Satin Purple 97 GTP
    Blue 01 IS4 + M112 hybrid GTP
    Satin Black 98 Turbo GTP
    ZZP recommended installer - Kratos Concepts
  9. #9 Re: 18" rims with Turbo
    Jul 2008
    didnt GM have a true race axle for our cars? thought i read that somewhere on the boards.
  10. #10 Re: 18" rims with Turbo
    GM racing made parts for the sobalt, not for our cars.
    somehow the chain was applicable to ours as well as the diff if i have my facts right.
    Which i probably dont.
  11. #11 Re: 18" rims with Turbo
    SE Level Member BlackGS's Avatar
    Central Jersey
    The only "racing" axles made for w-bodies came from SFPH:
    South Florida Pulley Headquarters - Your source for supercharged performance products!
    If you watch the video, you'll notice that is Zoomers twin-charged run.
    I run 18's on the street without problems. I have the stage 2 zzp axles. I did snap a wbody store axle at the track on 16" DR's a couple years back. I'd guess traction is more likely to break axles than weight.
    2000 Regal GS | Stattama Twin-Charge with Comp Turbo 6765 | 12.55 @ 110 15psi | Now running 20psi on E85!! |
  12. #12 Re: 18" rims with Turbo
    traction is directly dependent on weight.
    hence fosho always saying the 7/8ths chain is good if you can get your race weight down to 2800/3000 lbs. Much higher and you need the 1".
  13. #13 Re: 18" rims with Turbo
    Nov 2009
    Canada
    Im pretty sure those are the half shafts in my car now.. They sell them on ZZP as well.
    Im gonna go ahead and mount the 18's i wont really be launching that much anyways. but what happens if i go from say a 40 km/h roll?
  1. Turbo Build "UPDATED 12/22/2010"
    By bbptech in forum Turbo
    Last Post: 12-22-2010, 12:06 PM
  2. GMR 1" Chain/Gears for Turbo/Twin Charged
    By japslpr in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-01-2008, 09:36 AM
