Thread: Benefits of Blocked SC case to L26/L36 UIM .
Results 1 to 3 of 3
  1. #1 Benefits of Blocked SC case to L26/L36 UIM .
    SE Level Member oldsman105's Avatar
    Queens, New York
    Hi.. I am researching a turbo kit for my car and have read about people using the L26/l36 Intake manifold compared to the blocked off M90 case. What are the benefits to this setup compared to the M90 casing?
    2002 Pontiac Bonneville SSEi
    Gen V with 3.6 pulley , 1.9 Rockers, L76 Springs, N* TB, 40lb injectors, Power log, 3" Down-pipe
  2. #2 Re: Benefits of Blocked SC case to L26/L36 UIM .
    I live here. UR LOSN's Avatar
    Rockford, IL
    Mot of the GTers use the stock L36 UIM....but..the L26 UIM wont shatter under HIGH boost.......
    the L26 is a better option....and with a little modification will fit onto the LIM of a L36.
    the blocked off SC housing is what most SC cars do...as it is little to no modification.
    if you were to add the LIM from a L36/L26....onto your L67/L32....you would have extra injector ports...as the L67 fuel injectors spray through the heads.....
    you would either have to block these ports off....or it would be a good time to add a direct port nitrous kit ontop of it..lol depending on how big you want to go.
  3. #3 Re: Benefits of Blocked SC case to L26/L36 UIM .
    GT Level Member Meemperor's Avatar
    Toronto, ON, Canada
    Tap the LIM and use threaded pipe fittings, its' cheap and easy (If you don't want to use the spray !)
    Lumpy Gen 3
  1. Benefits of ant EGR delete ?
    By stlmo_gtp in forum General Tech Discussion
    Last Post: 05-27-2012, 05:39 PM
  2. L26 intake v.s. Blocked off supercharger
    By Andrew_99GTP in forum Turbo
    Last Post: 11-03-2008, 09:05 AM
  3. turbo manifold >?
    By sal3800 in forum Turbo
    Last Post: 04-09-2008, 06:33 PM
  4. Do you see huge benefits in premium/hi-test/whatever you wanna call it.
    By Edmonchuck in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-03-2008, 08:11 PM
  5. EGR Delete Benefits/Discussion
    By TyroElite in forum General Tech Discussion
    Last Post: 01-05-2008, 04:39 PM
