Thread: Garrett 50 Trim
Results 1 to 10 of 10
  1. #1 Garrett 50 Trim
    Greenville, SC
    How well would a Garrett 50 Trim with .62(?) A/R pair with the 3.8?
    Im thinking full spool rpm, and power limitations.
  2. #2 Re: Garrett 50 Trim
    Feb 2009
    flintnasty MI
    Would be painfully similar to a M90.
  3. #3 Re: Garrett 50 Trim
    Greenville, SC
    Wow I cant believe someone finally answered. Thanks for the input, whats a relatively common turbo that would be big enough for the 3.8?
  4. #4 Re: Garrett 50 Trim
    Feb 2009
    flintnasty MI
    I use truck turbos fairly successfully. As far as common gas turbos, I don't think there is such a thing. The factory grand national turbo may work, but it is also fairly similar to a m90 in terms of flow.
  5. #5 Re: Garrett 50 Trim
    Greenville, SC
    with the "truck turbos", at what rpm is full boost? I dont want something with alot of part throttle boost, I have a 3500 stall.
  6. #6 Re: Garrett 50 Trim
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    well lets say that with the "truck turbo" holset hx35 on a 2.0 or 2.3 liter 4g63, it hits full spool with a t3 housing at abour 3k-3200 rpm. you are pushing almost twice the flow capability with almost double displacement, so i would assume that you would be getting full spool potential around mid 2k rpm range. believe me, a holset hx40 would be deadly on a 3.8 liter...hitting a lot of boost at 2600rpm and full peak psi by 4400rpm, insane! i dont think that transmission will hold up too long with a holset on it...better talk to triple edge about a custom jobby
  7. #7 Re: Garrett 50 Trim
    Jan 2009
    san diego
    and the hx turbos flow from 54lb min of air to say, 65 or so for 7 blade billet hx40 compressor. just saying, thats a lot of air...
  8. #8 Re: Garrett 50 Trim
    Greenville, SC
    what trucks have the hx40 stock?
  9. #9 Re: Garrett 50 Trim
    Feb 2009
    flintnasty MI
    HX40s come on mostly commercial diesels, there are tons and tons of different low volume vehicles that use them. I would say far equipment is your best bet.
    HX35's come on the very common 5.9 dodge cummings turbo diesel. Many of these around, and the turbos have been constantly developed in the 20 years that they have been using them on the dodge's. Get the newest style stuff you can find, any of it will work, even the VGT version if you wanted to get fancy.
  10. #10 Re: Garrett 50 Trim
    Jan 2009
    san diego
    my advice is to troll on cumminsforum.com and buy one cheap there. they have them from 200-500 bucks all the time...
  1. B-pillar trim
    By luk909 in forum Visual/Body Modifications
    Last Post: 02-22-2010, 10:41 PM
  2. I need some trim....
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 09-12-2009, 11:06 PM
  3. door trim
    By evilpacker in forum Visual/Body Modifications
    Last Post: 07-29-2008, 03:12 PM
  4. T3 Garrett Turbo + GM 3.1L V6= ???
    By Quicksilver_GP in forum General Tech Discussion
    Last Post: 04-27-2008, 06:05 PM
