Thread: my trans vs. turbo
Results 1 to 6 of 6
  1. #1 my trans vs. turbo
    Jersey
    Since my car is no longer a daily...I have been considering to de-mod my m90 setup, ditch the L36 and go turbo/L67 instead. My trans was built by Dave and was installed this past December. The trans has the following upgrades...
    -Intense input shaft
    -Ls4 style chain sets
    -HD diff
    -stock gtp torque converter
    I was really eying up the z7 kit from zzp and wanted to run my 1.9 yella terra rocker arms with it, even possibly spray meth/alky.
    On another note, what kind of manifolds are you guys using? stock?
    16' wrx sti- stock
  2. #2 Re: my trans vs. turbo
    Charles City, IA
    You at least need a rear turbo manifold and cross over. Your trans should be able to hold up pretty well.
    SMGPFC Two Nipple General
  3. #3 Re: my trans vs. turbo
    Jan 1970
    Maquoketa, Iowa
    z3 kit, front stainless plog, #65 injectors, intercooler and call it a day.
  4. #4 Re: my trans vs. turbo
    Jun 2010
    Dallas Texas
    If all you have is trans mods you listed I doubt you'll have it functioning for long. The LS4 cars eat transmissions like candy and I don't see anything beyond parts that come on the LS4 tranny in that list. Remember this is at 300hp and 323tq.
    You can easily push past that with a turbo setup. Instead of a L67 you may consider an L32 as well, IIRC you will be starting with stronger internals.
    Good luck!
    2006 GXP
  5. #5 Re: my trans vs. turbo
    Aug 2008
    so cal
    I'm using the powerlogs front and rear if its not a daily I think that would be okay for awhile. You should hit up Dave see what he thinks.
  6. #6 Re: my trans vs. turbo
    State College
    Quote Originally Posted by 99prixgt View Post
    -HD diff
    your trans should be ok for a while.
    many keep their m90 housing and remove the internals.
    if you want a better flowing setup, you could go with an L36 LIM with injector holes plugged and L36 UIM.
    99 Buick Regal - lots of stuff, lots of power, tons of fun watching LSX's disappear in my rear view mirror
    www.fquick.com/mtsman
  1. Trans only or Trans + Engine
    By 98GTKen in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-23-2008, 12:01 AM
